41 - 44 of 44 Posts
Discussion starter · #42 ·
Fix it...
After changing:
front right lower and upper arm
drop links
2 sets of brake pads
2 brake discs
1 wheel hub
2 sets of pins
2 sets of anti-rattle springs
2 visits to mechanics
one caliper
2 bleedings of the system.
It was the rear right caliper anti-rattle spring, it snapped and the pads were rattling inside caliper ( no ratling when pressing the brake pedal ).
Thank all your help!
Are you 100 percent certain the noise is coming from the front ? ?
As when you hit the road surface it can be missleading and be from the rear not front .
To pinpoint the noise you need good hearing and some skill . :grin:
I think someone on here was correct . >:D
There does not seem to be much wrong with them!
Are you sure that is what is causing your noise. Would need to be quite a jolt to be heard and the impact would drown out that small click.
Can not imagine them pads "rattling"!
:wink:
Glad you sorted it out.
Also you have sorted out that bent hub, which would have caused many more problems in the future :tu:
41 - 44 of 44 Posts
