61 - 80 of 128 Posts
Discussion starter · #63 ·
Not had access to my notes for a few days
The menu items for the settings screen need adding to enable the units to be changed over
Numbers 4, 5 and 6 need enabling
Found in INSTRUMENT CLUSTER .......................... VARIANT CODING --> READ CODING AND CHANGE IF NECESSARY
Make that options 4,5 and 8 - slight typo there
And yes to the reset.
Save
I had a go at changing the lower mfd from kph to outside temp and it never went well.i followed the steps I have and set the the uk variant to aus.saved the changes and then did a instrument cluster reset.my time clock started winding backwards and then forwards.and the kph in the lower mfd changed to mph (not outside temp) using the steering wheel controls I can toggle it between kph and mph. so any idea why it never changed to outside temp like it should have done
I can't help with DAS, but now that you've set things to Aus, and you can see mph in the lower MFD, is there an option via the steering wheel controls to display outside temp instead of speed (which should then show in the lower MFD)?
Save
Discussion starter · #65 ·
Enabling those menu options via DAS puts those options on the settings screen(s) if they're not already there ...
Reactions: dbgrn
Save
ive not yet tried the settings 4 6 and 8 sean said to do,as it is now I can toggle between kph and mph from the steering wheel controls for the lower mfd
but no temp option as yet
Discussion starter · #68 ·
Thanks very much sean I will give it a try.
do you know why when I changed the kph to show Outside temp it changed it to mph instead ?
It's because the car's region has been changed and it's showing the opposite unit of what should be on the speedo
ie
UK - MPH on speedo, KMH on the display
Europe - KMH on the speedo, MPH on the display
It's a mis-interpretation of one of the rules that says a speedo must be able to display KMH as well as MPH (or something like that ... @Woolly has posted some info on this a while back)
Save
Discussion starter · #70 ·
It varies - on some cars I've done it's gone straight to the outside temp - others have needed the menu options to enable the temp / mileage to be flipped
Save
connected up to car day,menu 4 was in german it began with a "V" can remember what it was,clicked on the drop down arrow and there was nein then this v word,so left that as it was. what is this one sean??
menu 6 wasn't enabled so enabled this
menu 8 wasn't enabled so enabled this also
now I can switch between Kph,Mph,Temp in degrees c and Temp in degrees f
cheers for the help sean it seems to be working now
all done!
enable both rear fog lamps--tick
enable cornering foglamps--tick
enable alarm chirp--tick
enable fuel remaining--tick
enable temp in lower mfd.toggle between temp/speed--tick
enable rotational tyre run flat--tick
would have liked to have done flash rear brake lights under panic braking,but not on the menu on my das/xentry.....is this only a option on certain models/countrys ????
BIG BIG thanks to sean and others for the info on doing these codings to make it all possible.
Save
