41 - 60 of 128 Posts
Can these tricks etc be carried out offline or does it have to be scn online ?
They are offline, you are not reprogramming or updating, so there is no need for Online SCN.
Most of the tricks are model (Programming) specific, so you may not find a specific trick you are looking for, or maybe you find a new trick which is not documented.
Thats very kind of you, but im in the uk.
so these das with c3 and laptops that are for sale on the internet would these work?
I belieave in what ive read that they are just copys and not the genuine equipment or software?
Quality varies, best to deal with a known supplier. C3 is not supported by the current software versions.
Discussion starter · #45 ·
It's a different mode of DAS, thats all
Allows access to more complex stuff .. along with more potential to make a hash of things too
Save
need to pop out to the car to confirm the exact steps (I'll sort this shortly), and they give you the following extra's in the settings menu on the upper MFD (if you don't already have them)
The ability to change the DISTANCE units
The ability to change the TEMPERATURE units
The ability to change TEMPERATURE and SPEED around in the lower MFD
Did you post the procedure for the above ?
I can't find it posted.
Discussion starter · #51 ·
Would an indy garage charge to have any of these changes done?
Cheers
Joe
Morning ..
They probably would - it takes time ( even if it is a fairly quick job), and whilst they are coding your car, they won't be working on someone else's ...
Reactions: joemackem
Save
Discussion starter · #52 ·
Morning ..
These won't be available unless you've have coding done before-hand to change the standard lower diplay to outside air temperature instead of KMH ...
Save
das sim mode
.playing around in the sim mode trying to enable fuel remaining in tank.got to control unit adaptations, I then have read coding and or transfer download data to new control unit. And I also have control unit adaptations (download). I dont have a variant coding.
connected my das star setup to car today for a play around
enable both rear fogs--done
enable conering foglamps --done
alarm chirp lock/unlock--done
so not a bad morning in all ,A big thanks to sean and others for posting the procedures on how to do these precedures
when I couldnt find variant coding menu I was in xentry sim mode .I know my set up does have a xentry developer mode so I'm hoping when I connect up to the car the variant coding menu will then be displayed. thats what I'm hoping
did some more coding today and changed lower display to show outside temperature.
could you please post procedure to do the following.
thanks very much
I had a go at changing the lower mfd from kph to outside temp and it never went well.i followed the steps I have and set the the uk variant to aus.saved the changes and then did a instrument cluster reset.my time clock started winding backwards and then forwards.and the kph in the lower mfd changed to mph (not outside temp) using the steering wheel controls I can toggle it between kph and mph. so any idea why it never changed to outside temp like it should have done
Discussion starter · #60 ·
Not had access to my notes for a few days
The menu items for the settings screen need adding to enable the units to be changed over
Numbers 4, 5 and 6 need enabling
Found in INSTRUMENT CLUSTER .......................... VARIANT CODING --> READ CODING AND CHANGE IF NECESSARY
Save
