The Ultimate in CTEK Install
1 reading
3.2K views 21 replies 7 participants last post by  Trev5
#1 ·
This is for 171 ( Facelift ) Owners more so.
Hard Wired Direct to Car Battery using CTEK Cabling so no longer Req bonnet up connection purposes and ideal for Easy connection Access for winter Hibernation and those that indoor Cover there SLK’s .
Plus no signs of instillation signs under the Bonnet . 😎😎
Note : This install met my requirements but may not suit all.
#6 ·
Cool! and the original from Dr Eddy/etyu
#12 ·
#20 ·
I added a 12 volt socket in the rear console cupboard. This is wired (fused) to the battery. Then the Ctek can be plugged in there. You will see the connected cable when you drive off;). The socket is also handy for conceiled charging your phone when the car is parked. Ctek is mounted on the garage ceiling above the drivers door
And a switched socket for the TomTom in the glovebox while I was at it.
