For our friends that have long winters or those who store their vehicles, who wish to have a battery trickle charger while the vehicle "hibernates", this thread is for you.
I bought the Battery Tender Plus (r) Battery Charger this afternoon as I plan to trickle charge/condition the 12V car battery on weekends. I also decided to install the ring mount pre-wiring that came with the battery charger as I didn't want to deal with the battery clamps. This will make charging/conditioning the battery a simpler plug-and-come-back-later deal.
Below is a pix of the completed pre-wire install:
The red arrows point to the positive wire with the + ring terminal attached to the positive end of the battery.
The blue arrows point to the negative wire. This has been threaded through an unused rubber grommet (in the firewall to the battery compartment, highlighted by purple circle) and routed to one of the factory ground in the engine compartment (the bolt is highlighted by a round orange circle in the pix to the right). The negative wire is also anchored by plastic tie and covered with soft rubber at this junction (green circle).
The covered connector for the trickle charger is highlighted by the yellow circle to the left of the pix. This connector may be threaded out the vent at the front side of the battery cover if so desired. I probably will tuck this near the vent so that it is easy to locate and fish out with one hand. If not the battery cover is easy to remove anyways (just turn the three twist anchors 90 degress to release, one in front and two in the rear).
Tools needed: 10 mm hex head, a small 5-inch ratchet wrench (bought this for 98 cents at Marukai 98-cent store in Fountain Valley).
Tips and procedure:
1. Make sure to insulate the ratchet wrench while working to loosen the bolt at the positive terminal of the car battery. I used a small PVC tube that fits into the handle of the wrench. See pix below:
2. Thread the negative ring mount through the rubber grommet first.
3. The unused rubber grommet is easily removed by sliding upward (after the battery cover is removed). You will see a U-shaped cavity. Use a small chisel Exacto blade (2mm wide) to cut through the rubber that covers the u-shaped cavity. Follow the U shape so that the top of the U is uncut and the result is a U-shaped flap. The negative wire ring mount will go through the rubber grommet easily with minor effort and I used a rubber sleeve to protect this junction (purple circle). Cover the negative ring terminal with electrical tape temporarily to prevent short circuits.
4. Attach the positive ring mount to the positive end of the battery. I recommend wearing rubber/nitrile gloves when working at the positive terminal of the battery. Do not loosen the main ring that attaches to the + battery post or you'll loose your settings in the vehicle (e.g., electric seat memory settings, or preset radio stations). Loosen and remove only the 10 mm bolt and slide in the ring mount and retighten the bolt. I like the 7.5 amp fuse built into the positive wire of the pre-wiring for safety. Replace the flat red plastic that covers the positive battery terminal.
5. Route and anchor the negative wire in the engine compartment. Remove the electrical tape used earlier to cover the negative ring mount. Attach the negative ring terminal to the factory ground in the engine compartment (this uses a 10mm bolt as well).
6. Replace the battery cover. Or you may wish to start the trickle charge procedure. Follow the instructions as provided by the manufacturer. Do not plug into AC outlet until all the connections are done on the battery side of the trickle charger.
7. Happy trickle charging or conditioning the battery
I hope the above is helpful.
Tips and procedure:
