I just got my '55 (R171) and it's running on 235/35/R19 (8J) and 265/30/R19 (9J). Previous owner did that.
I only had the tail wiggle a bit once when I stepped on the (heavy) throttle, but I also didn't really go fast yet since I a) just have the car b) am used to an AWD W164 ML63 on 295/40/R21 c) didn't have a lot of road to play with the car.
What are you guys using and are you happy with the setup ?
Would I/you/me notice a tire 1 size wider or or narrower ?
225 vs 235 vs 245 at the front and say 245,255 or 265 at the rear?
I recently watched an excellent test by Tire Rack:
Which can be an eye opener regarding tire width vs rim width.
Tyre Review also has a good test on tire widths but they don't switch rims, still a very good objective comparison with track times as well:
In short I noticed my REAR 9J rims can support a width up to 265mm (so it is at it's maximum width) while the fronts are on 8J with 235 which is the 'recommended' width. Would changing from 265 on the rears to 255 or even 245 (with 235 being the narrowest you should do on a 9J rim) matter much ?
Or is our '55 not enough "Sportscar" like a Z4 or Boxster or Cayman to even feel the difference in normal sporty driving? Not on a track ; no track here at this moment. I also don't do any autocross or other competitive driving, I just occasionally floor the throttle under overpasses and in tunnels
