I've taken the CF Plunge...
149K views 406 replies 126 participants last post by  jbanks15
#1 · (Edited by Moderator)
Evening all..
Having seen a couple of threads detailing covering the rear C pillars (vs replacing..) I've decided to follow suit...
My pillar covers had one or two small scratches, nothing major, but I know they're there....
So, one roll of fairly high quality CF film later..
Before & after pics now attached
Subtle, but far tidier..
As per other posts, all I did was cut out a larger piece thanthe cover, stick on (working from the centre outwards to remove bubbles) and then trim in situ with a new scapel blade (X Acto for those over t'pond) - simples...
I'll take a look at the front bumper vents (as per the Black Series bumper) too, but not much more... don't want to over do it...
Sean
PS – check out http://www.slkworld.com/united-kingdom-region/31725-east-midlands-rabbit-chase.html for info on the possible East Midlands ‘Rabbit Chase”
Mods so far...
Airscarf Retro-fit http://www.slkworld.com/general-modifications-r171/27470-project-airscarf-starts-here.html
Alpine double-din touchscreen head unit with Bluetooth, Nav, DVD, reverse camera and iPod with a ‘Small’ sub in the boot
http://www.slkworld.com/slk-r171-general-discussion/26915-amplifier-location.html
Mercedes Genuine rear Windscreen
http://www.slkworld.com/general-modifications-r171/32951-new-windscreen-one-back.html
Display& steering wheel integration for the head unit.
Digital Climate control panel, Sun sensor and Pollution sensor fully working
http://www.slkworld.com/general-modifications-r171/30240-climatronic-retrofit-digital-climate-control.html
Hat-shelf mounted solar charging panel
Rain Sensor for Auto-wipe retrofit
Various coding changes to the Instrument cluster – see below
AMG Aluminium gear change paddles instead of the buttons
http://www.slkworld.com/general-modifications-r171/31587-amg-aluminuum-gear-change-paddle-retrofit.html
Facelift SLK Antenna http://www.slkworld.com/general-modifications-r171/32272-facelift-antenna-tick-otherwise-known-two-minute-mod.html
Harman Kardon speaker upgrade – All 11 !!
http://www.slkworld.com/general-modifications-r171/31530-hk-speaker-upgrade.htmlCustom dimming LED DRL’s http://www.slkworld.com/general-modifications-r171/32992-looking-drls.htmlLED’s… in various places…[x] - Map…[x] – Dome…l [x] – Number plate…[x] –Side…[x] – Puddle http://www.slkworld.com/general-modifications-r171/33120-leds-were-all.html
Full blown TPMS…
http://www.slkworld.com/general-modifications-r171/33263-tpms-retrofit-its-started.html
Auto Dimming rearview mirror with integrated GPS Speed Camera detector BEHIND the glass….
http://www.slkworld.com/general-modifications-r171/35096-my-solution-dimming-interior-mirror-look-away-if-you-dont-want-see-things-getting-cut-up.htmlPower Folding mirrors… http://www.slkworld.com/general-modifications-r171/33942-folding-mirrors-making-start.html
Designo style Alcantara head lining / A Pillars and various other bits….
Johns 3rd brake light gizmo
http://www.slkworld.com/general-modifications-r171/15456-johns-3rd-brake-light-adapter.html
Mods in progress
Parktronic retrofit – nearly all the bits are here….. Just need the main loom now….
…soon this section will be empty …!
Mods on the wish list
Maybe a Smarttop....
Illuminated Sills – I have a cunning plan…
Coding Mods… http://www.slkworld.com/slk-r171-general-discussion/31073-my-adventrures-star-diag.html
[x] - Enable those pesky phone buttons on the steering wheel - FINALLY DONE - WOOHOO
[x] - Enable Auto-wipe – done
[x] - Add temperature display to the lower MFD - done
[x] - Enable tyre pressure Loss Warning - done
[x] - Enabled Folding mirrors – done
[x] - Enable Gallons Remaining in the MFD – done
[x] - Enable Cornering Fogs - done
[x] - Enable both rear fogs - done
[x] - Enable Alarm 'chirping' – done
[x] - Enable TPMS display in the upper MFD – done
[ ] - Enable Highline TPMS – proving tricky!!, but we have some great brains on the case….
#2 · (Edited)
Sean, Great job as usual. but what brand cf are you using, (link)?
Also see: Rear pillar vinyl covering
#3 ·
#221 · (Edited)
I did some research on some of the films, settled on the embossed one (to remove the potential for bubbles) and ended up with this
3D Catpiano Carbon Fibre Vinyl Sheet Wrap Sticker Film ALL Size, AIR/BUBBLE FREE | eBay
OK price wise, quick to ship (in a very sturdy tube) - got a couple of metres to play with... (the C pillars don't use much...!)
With a little time on my hands and a faded parcel shelf I decided to join in with the Carbon Rap. Found a guy in the next village who supplies 3D 152 X 55 for 19€ including postage. When I collected the package from him he gave me 5€ back which he saved on postage - how honest is that!!!
Autocollant Sticker Adhesif Carbone Noir 150 X 50 CM Special Tuning Auto Moto | eBay?
I do intend to get this job done by a pro at some time (and also the sill covers) but I learned a lot from the test.
1) I did it all "freehand", I'm not good with a scalpel but it still looks OK. I think 3M would need a template and a lot more care to avoid wastage.
2) Cheap film needs to be handled carefully to avoid marking the surface but it's fine once it's firmly stuck.
3) It's easy to take off and reposition.
4) The edges will only stick to a flat surface so wrapping the edges wasn't going to work - is 3M better for this?
The matt black looks really good against the matt grey paint.
#9 ·
Great work Sean !
Once again SLKWorld members come up with multiple options (I think this is #4 - replace, wax, paint, CF ) for owner's to fix one of the car's substandard components.
If only the seat bottoms were so easily remedied. :biglaugh:
#11 ·
Jeff,
If I read it right an order of 1 linear foot for $19.99 will get you a piece 12 inches by 60 inches. Enough for your car and mine too ! Want to go halfsies ?
Reactions: Daff9272
#14 ·
Jeff the CF3D2 and CF3D3 have an End Use Temp of -4F. That maybe ok if you never leave Florida. It looks like I will have to get the expensive 3M stuff with End Use Temp of -65F :(
...This is Jeff we're talking about...-4F ... I think he'd walk instead!!!!:biglaugh:
I don't think Florida gets that cold... (Although it was pretty chilly when I was over there a couple of years ago Jan/Feb 2010 - to watch the last night time shuttle launch, but it was at 4am ish when it lifted .... temperature was fine during the day)
Sean
Reactions: jbanks15
#15 · (Edited)
More CF...
...So, back onto the original thread topic....
Added a small CF panel to the side grill vent on the front bumper. (both sides!!)..
Not sure if I should do the rear-most one too... may have a go tomorrow and see how it looks... (I'll wrap it round the bumper and into the wheel arch if I do do it...)
Sean
Mods so far...
Full blown TPMS…
Mods in progress
Reactions: etyu
#25 · (Edited)
..Afternoon
Thought I'd have a go at covering the silver trim either side of the steering wheel... (under the instrument cluster)
They both pop off, and an off-cut of CF film and a session with the hair dryer later...
Other side is the same - will post 'as installed' pics later
Sean
Mods so far...
Full blown TPMS…
Designo style Alcantara head lining and various other bits….
Mods in progress
Reactions: SlickSLK300
#30 · (Edited)
I'm just doing the silver trim thats over the glove box (to keep the look right)... might do the steering wheel button surrounds IF I can find / make a suitable pair of templates...
Sean
