9023 - SRS light on. Took the battery out to clean and charge. Worked on coils, plugs, AC charge.
Fired it up - SRS light stays on now. New development. I was working on the left wheel speed sensor wire replacement if there is a correlation.
"Component or signal line to the component B48 (front passenger seat occupied child seat condition) has a short circuit to ground."
B48??
SRS fuses check out ok in the engine bay. Wasn't working on the SRS system. Just a left wheel speed sensor cable replacement. Later found out that on the engine side of the connector, somebody snipped the wires both off right at the connector. Impossible to see, impossible to get to from top. Need to pull the wheel again, and try to follow where those wires
go.
B48??
go.
