21 - 40 of 64 Posts
... I found one of my brake tail lights not working...
I just realized you said brake/tail lights. On your car those lights are actually LEDs already and they are not replaceable, assuming you have stock lights, not after-market.
It's kind of unlikely that all the LEDs burned out together. If you really meant brake/tail (in other words, the bottom one-third segment of the light), then it's possible something else is going on, like a wiring problem.
tail light removal and replacement thread thanks
About a month ago I bought my wife her new dream car - 2006 SLK-280 black with the nice cream interior - a bit rough but worth fixing up. Not a real good wrench but DIY er when I can. About a week after we got it, I noticed water in the drivers side tail-light and then within several days, three messages showed up saying lights in both tail-lights had gone out and it was using alternate bulbs.
Turns out the LED's on the bottom had stopped working for the brakes, and the upper fog lights were taking over the function on both sides. I figured I needed to replace both tail light assemblies and started searching around for new parts. I ended up ordering two new tail-lights from Mercedes-Benz Parts and Accessories | MercedesPartsCenter.com each one OEM MB for 135.43 and 24.00 shipping for the two. They arrived within a few days and today I followed all this great threads guides and pictures and took mine apart and put the new ones in. All worked great and the three messages went away as soon as i plugged the new one in. Little tight but great guidance and I figured it was my responsibility to thank those involved and perhaps this can help someone in the future. Brian
Thanks to Durkatlon for showing and explaining the procedure as we met this morning to remove ponia003's tail lamp assembly and install the AMG tail lamp (with the central horizontal smoked area).
Credit goes to Durk for explaining and demonstrating the procedure, and to Dan for the demonstrator vehicle.
The procedure has been described and illustrated in the following posts:
1. Link to John's (UK-C200) post: http://www.slkworld.com/slk-r171-general-discussion/10397-tail-light-removal.html
2. Link to Zeiser50's post on removing the center panel in the boot/trunk: http://www.slkworld.com/slk-r171-general-discussion/3611-remove-paneling-rear-center-section.html
What follows is mainly a supplement to the above 2 posts, and perhaps the accompanying photos will make the procedure clear. This is by no means comprehensive and does not replace what a skilled and trained authorized technician may provide.
I can 'sense' Jeffs' fingers itching to zap me for replying to an old post.
Thanks to Eddy, Durk and Dan for putting this lot together.
Detailed photo's are a real plus when dismantling anything. These are spot on.
I'm only updating bulbs but wanted to make access as easy as possible.
Avoids the issues of dropping things into inaccessible areas.
Having just updated the front indicators to Cree bulbs, I'm doing the same in the rear.
Front was straight forward, but a real pain on having to have small hands and the dexterity of a magician. That's someone with 40 years experience on rice burners
This detailed procedure to remove the tail lights worked fantastic,
Thanks for sharing Eddy/Durk.
The only minor issue is that I could not fix the problem!
Once I got access to tail light backside, I removed the fog light bulb
The bulb filament seemed fine, wire continuity ok.
So, I installed a new bulb I purchased from Pelican parts, PN 000000-008156-MBZ, genuine 21W, long life fog bulb.
It didn't work.
Cleaned contacts with contact cleaner and emery cloth,
And still not working.
An interestin thing to point out, I measured the voltage in the bulb socket and it gave me intermittent 0-12 V.
Now I don’t know if this intermittent voltage is due to lack of resistance from my multimeter or an actual problem with the tail light module.
Any help will be very welcome.
Thanks!
I see one reference in here to "replaced my tail light in under an hour."
If I've never worked on my SLK before (worked on other cars, but I'm no automotive genius), and my goal is to take out the trunk lining to see if a service place forgot to reconnect the sensor to the trunk partition latch (the one that registers if it's closed so I can put the top down), how long should I allow to take out the trunk linings, look around in there, and then close them back up? (I'm figuring if it's just a connection that was left undone, that'll only take a few seconds to reconnect.)
if you have the instructions and tools, maybe 30 mins to remove. You need sonething to keep the boot lid in "assembly position", i use a 6' stick for this.
I assume the switch itself is in place (no hole where the switch should be)? It is possible that they didn't plug in the connector. To figure that out you'll have to unfortunately get the big plastic piece from the near end of the trunk that goes all the way across. Basically you'll be following the instructions in this post until you get to this picture, where the switch you're looking for is pointed out:
Discussion starter · #32 ·
I would allow 60-90 minutes (probably overestimate) : just take your time and be methodical. It also helps if there is another pair of hands to help in holding and moving things around.
Save
Thank you so much I am getting familiar with the site and how to post buy as yet an amateur You are ALL so amazing I wish I could figure out how to say that to the whole community
Henry
+1 :frown:
Whats happening ? :nerd:
PhotoBucket have decided that they can't afford to host pictures for other websites for free anymore. So anyone that's been linking from here to there now has to pay up, or watch the pictures fail to load.
It would be better to use imgur or somesuch, or better yet, host the pictures on slkworld itself. Unfortunately that has size restrictions and I think also a total-space restriction for a non-premium user.
Picture issue...slow days at the dealer.
Unfortunately we have learned that the "cloud" isn't forever....probably best for the DIY ones to embed the pictures into the thread. Other than the occasional rotation issues it is quite easy. However I don't think you can put pictures in between paragraphs so perhaps name them with a number or title and then reference to them in the text.
This is a test...
And now this one.
Did not separate...all at the end still.
Perhaps create the DIY document in its entirety in WORD and save as a PDF and then attach to the thread. Any other ideas?
Baja-D
Save
21 - 40 of 64 Posts
