Foxwell NT510 Elite for MERCEDES BENZ Full System OBD2 Diagnostic Reset Scanner about $142 US on the Bay. Plan on using it on 2002 32 slk AMG.
Hi,For in depth scanning I use an Autel Diaglink with the Benz module also from AZ
Is not Torque Pro more so for Displaying your cars performance ,temp blah blah on your Mobile phone while driving as well as if it can read codes but debatable if it will clear many ?We are tallking R170 here (and the Chrysler version that we mustn't mention) ? Not later cars like R171 (or other OBD compliant cars 2004 up Fords, Chevys etc) ?
On Mercedes R170 I'd expect it to have ....
Motor ECU
ABS / ESP
SRS / Airbag
Transmission
I would be surprised, very surprised if it got ATA, PSE, CCM, Audio, VR, ICM, Audio and a few others I can't think of now, because I've never come across anything that can emulate HHT
I actually evaluate new machines for a local motor parts wholesaler, so I get to see all sorts and always try them on R170, W638 and any other old MB's I might have laying around waiting on parts
I came across this before with iCs and R170, an owner was seeing a list of modules but could not get any data out of most of them (i.e. fault codes / live data / actuations etc) that guy had assumed that was because there were no faults, when in actual fact the list was just a list, but no connection to the actual modules
May be worth you checking if you can get any temperature info for HVAC, door switches in ATA, stuff like that
IDK, like I say, just curious![]()
Now An Autel 906 Model is a great little machine and improving on each newer model that gets released every year ,BTW I collect scanners and have both Torque Pro for quick and dirty & parameter display while driving. My go to scanner is an Autel Diaglink with the Benz module (note $10 coupon) that does more internal modules than I can count (think full list is on Autel's web site). And an Autel MS-906 but prefer the DiagLink. Also have some PC based scanners including the MicroPod. Am thrying to find out if my Carly for Mercedes covers R170 now but have been communicating since 23 Feb (at least 10 emails) and verified I have a license but so far have failed to receive needed credentials.
Only if they are OBD Compliant, it will not do all on R170 and similar tech Cars !!As mentioned the MS-906 does everything for all cars and has a $$$ subscription available
OBD ports come in circa 1995 / 1996 for UK / Europe cars. ( maybe sooner maybe a year ish ??? )Gee, dunno. My Autel worked just fine with 16 pin OBD connector for my 2000 SLK230 (gone) and 2001 SLK320 (sill have) and (unmentionable) 2004. Understand US cars got OBD-II sooner than other countries.
ps have a 38 pin, never used it.
pps just a hobby and for my personal cars. Is the best I've found for under a Benjamin.
History of OBDIIOBD ports come in circa 1995 / 1996 for UK / Europe cars. ( maybe sooner maybe a year ish ??? )
Mine was the short version 😂😂History of OBDII
The history of on-board diagnostics goes back to the 1960s. Several organizations set the groundwork for the standard, including the California Air Resources Board (CARB), the Society of Automotive Engineers (SAE), the International Organization for Standardization (ISO) and the Environmental Protection Agency (EPA).
It’s important to note that before standardization, manufacturers were creating their own systems. The tools from each manufacturer (and sometimes models from the same manufacturer) had their own connector type, electronic interface requirements. They also used their own custom codes for reporting problems.
Highlights in OBD history:
1968 — The first OBD computer system with scanning capability was introduced by Volkswagen.
1978 — Datsun introduced a simple OBD system with limited non-standardized capabilities.
1979 — The Society of Automotive Engineers (SAE) recommends a standardized diagnostic connector and set of diagnostic test signals.
1980 — GM introduced a proprietary interface and protocol capable of providing engine diagnostics through an RS-232 interface or more simply, by flashing the Check Engine Light.
1988 — Standardization of on-board diagnostics came in the late 1980s after the 1988 SAE recommendation that called for a standard connector and set of diagnostics.
1991 — The state of California required all vehicles to have some form of basic on-board diagnostics. This is referred to as OBD I.
1994 — The state of California mandated that all vehicles sold in the state starting in 1996 must have OBD as recommended by SAE — now referred to as OBDII. This stems from the desire to perform across the board emissions testing. OBDII included a series of standardized diagnostic trouble codes (DTCs).
1996 — OBD-II becomes mandatory for all cars manufactured in the United States.
2001 — EOBD (European version of OBD) becomes mandatory for all gasoline vehicles in the European Union (EU).
2003 — EOBD becomes mandatory for all diesel vehicles in the EU.
2008 — Starting in 2008, all vehicles in the US are required to implement OBDII through a Controller Area Network as specified by ISO 15765-4.
