How to refill Hydraulic Pump Hard Top
109K views 26 replies 16 participants last post by  tjblackmon
#1 ·
Hello,
Just got a 2000 SLK 230 and I need to fill up the Hydraulic pump for the hardtop. I've read that I need to remove the pump in order to fill her up but this seems a little complicated. Is there any plug in the pump that is used to fill her up? I see several TORX screws and I don't know if any of them is to be used to refill the pump. Thanks
#7 · (Edited)
Hi
Should be a screw on top of the pump - upper right side.
It should fit a hex/allen/unbrako(dunno what you call it) key size 5.
Oil level should be between min and max.
After filling, tighten screw with 8NM torque
EDIT: If you look down through the "brush", you'll see the screw.
#8 ·
Just curious, I would think that this should be a "closed system" where the fluid level ought to remain constant. Under what conditions would you need to add fluid to the pump? Was there a leak or bad seal or something that was replaced first?
#9 ·
Thanks. That is the correct screw. Hard time to refill it. Found that I have one of the hard top cylinders leaking big time. Have a one month warranty so they will fix it for me on Monday.
Some other info: Under normal circumstances you shouldn't need to refill the hydraulic fluid in the pump unless you have a leak. Due that I just bought the car and the pump looked so new, I thought that maybe it had been exchanged and it needed more fluid due that the system had pulled it all in (Bleed).
#13 ·
seiya1972, zhark,
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model.
And finally, if you find something useful on your visit here today, please consider donating for hosting and licensing fees to the site. Even $5 is welcome! Thanks!
Save
#17 ·
tinymimo,
New members and guests should be aware that the 'New Posts' link next to the 'Search' link top right of the info bar is a great way to see all of the posts you have missed since you were on the forum last. Remember to click 'mark forums read' under quick links when you leave.
Thank you,
Moderator/Founding Member
Save
#19 ·
aeee,
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Save
#23 ·
I have 2002 slk320 and I did it this way. I removed the cd player open the access panel drilled my own hole in reservoir, attached a piece of vacuum hose to a oil funnel and topped mine of with fluid. It took me about half an hour including making the funnel and tube. After I was done, I cleaned my reservoir surface and attached a piece of duct tape.
#24 ·
First please update your location and vehicle (year?: 1996-2017, model?: 32, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
If you wish to become PM (Private Message) capable, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM. You can always pm a moderator.
Save
#26 ·
Thanks for joining SLKWorld.com.
Please post an introduction:
Please update your vehicle/location details:
The reason that we ask you to update vehicle/location details is to save repeating the same
information every time that you ask a question.
Also, this site is truly worldwide. That can matter when you ask for help and information.
Are you looking for a bonnet, or a hood, a boot, or a trunk? Makes a difference.
Driving on the left, or the right?
http://www.slkworld.com/slk-r170-cl...0-class-diy/205121-vario-roof-troubleshooting-tree-r170-courtesy-leapyfish.html
http://www.slkworld.com/slk-r170-class-diy/422994-slk-repairs-youtube-stephen-paul-49-videos.html
Save
