How to change the oil, air filters, cabin air filter and reset the service reminder on an SLK55 AMG
11K views 15 replies 3 participants last post by  jbanks15
#1 ·
#3 ·
Just thought I'd run this by everybody, did an air filter change on my 2007 SLK55 AMG P30. Put in some new AEM dry flow air filters which have no oil in them, was always a K&N fan but their so loaded with oil thought I'd try something else and got a deal on Ebay. I encountered something that I have not found any information about. Came across "Post Air Filters" that look like cabin air filters. So I took them out considering I probably don't need "Post Air Filters", if anybody has any advise about this please chime in. Pictures are in a sort of DIY timeline.
Thank You
#5 ·
Yes... the yellow oem are Mann and the gray this ones are Mann as well... Theres a housing that holds the gray ones real snug, had to mush the gray ones to get them out. I have seen the housings for the gray ones(With no gray filter) in your posted youtube video about the white SLK55 DIY. Also V6 SLK's have a similar air box but they do not have the housings for the gray filter... I'm so confused....
#10 ·
That is strange, The gray filter housing is in the large main air box. I may try to "pop" them out. I did try to pry on them a little bit but it started cracking so I stopped. Are those the "Green" filter you have installed? The AEM ones I put make a nice sucking sound now, LOL. Going to drive the car tomorrow and see if there's a difference.
