Check engine light and error code
13K views 9 replies 6 participants last post by  Livefreeordie
#1 ·
Drove over to home depot today, about a 2 mile drive and when I came out to go home I noticed my car was making a funny noise. It was like a fan was working really hard. Kinda sounded like the car was trying to take off like an airplane.
Pulled over in the same parking lot and turned it off to make sure it was my car making the noise....sure enough it was. When I started the car back up the check engine light popped on and after a few seconds the gas gauge fell to E like it lost power. Also, the Comand unit shut off. Started the car up again and turned off radio, heat, etc. and the fan noise went away (think the fan was the heater going nuts maybe...I had the heater on cuz it was only 65 degrees out) but the light stayed on.
While driving home I noticed it was idling a bit rough..as low as 500rpm. Got home and ran my obd ii sensor on the car to find only one code, twice. P0600 was current and pending. Did some searching on other forums that recommended lots of stuff but I just don't trust other resources yet. Was hoping someone here might have some knowledge/info on the code or just the problems in general.
Thanks!!
#3 ·
Ok, so after a bit more testing, I think I have the problem isolated.
It only happens when I start the car with a power drain active. That is, the heater at full speed, Smart Top already moving or other electric device pulling energy from the battery.
I had already pulled the code off google to find it is the Serial Communication error, or Link malfunction....but the range of fixes I read were ideas from "replace x fuse" to "replace battery" to "reflash ECU" and even something about an "infamous wiring harness issue".
I cleared the check engine codes and it doesn't pop back on unless I start the car with other stuff on. i turned off the master switch for the SmartTop and the RemoteStart....even though I think the only one of the two that could possibly be causing my issue is the SmartTop. The reason I think this is because I have seen a post or two linking this problem towards the car's CAN bus....and since SmartTop links in there, maybe mine is shorting out or something.
Gonna drive for a few more days and see if the Check engine light comes back on.
#4 ·
If I were you, I'd open the hood, let the car go to sleep - about 15 minutes with doors closed, key out, etc, and then check the voltage of the battery, and then the current draw. You should have a very "sleep" draw - like less than 500ma.
If you have a higher draw, I'd start pulling fuses till you figure out what circuit it's on.
Other option is to run to a dealer or Indy who has SDS, and have them see what's up - they should be able to tell you exactly what device is throwing the error. I **think** P0600 is CAN-C, but I'm not at home, and don't have WIS to go play with..
#5 ·
danieleik,
I was wondering if you ever solved your problem. I think I havea similar issues as I describe below. I was wondering if you could give some operating experience based on your issue. thanks
Instrument panel randomly shut off W209 CLK500 Conv
2005 CLK 500 Convertible with 115k miles.
One of my light bulbs (the one that stays lit at night after turning of the car) burned out and I replaced it with a similar looking bulb before going to work.
On my way to work as I’m driving all of a sudden my instrument cluster shut off (the outside temperature and odometer still displayed but was not updating the miles driven). Also my radio shut off but I was able to turn it back on. I also heard the fan (believe it’s the radiator fan) working really hard since there was a lot of noise coming from the engine. I shut of the car and restarted and everything was back to normal.
On the way back from work the same thing happened but the car did not start right away. The key would not want to turn as if there wasn’t any electrical power at all. It eventually started on the 3rd or 4th try.
I came home and removed the light bulb I installed. The next day (day 2) the car worked without and problems.
Today (day 3) I took the light bulb from the good headlight and placed it in the burned out headlight and it worked. I also took the spare light bulb that I had previously tried to install to see if it would work one more time but it did not and I took it out. On my way to work the same thing happened as on the day 1, but this time it happened 2 times and when I arrived at work and restarted the car the check engine light came one.
I must also mention that for a while my info center on the instrument cluster has been displaying that I have several malfunctions associated with lights being either out or working when they are not supposed. I visually inspect it they all work fine, but it keeps telling me side markers lights are out or that the backup light is on when in actuality the side marker lights are on and the reverse light is not on.
#6 ·
rigal53,
Please update your location/vehicle (model and yr) in your profile as it helps the members answer any questions you might have based on locale and model and year.
Usercp at the top of page, edit your details, location/vehicle.
In addition, if you haven’t, please post your questions in the appropriate discussion forum for a quicker response.
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
Save
#7 ·
Rigal-
I think I have my problem isolated to an issue with power draw through the CANBUS. I'm almost positive that SmartTop is the issue, probably because of an error in installation on my part. I plan on tearing everything apart soon to re-check my installation.
It sounds like our problems are very similar. They both are probably caused by too much power being pulled at some point in the car, and some sort of "Breaker" being toggled. It's obviously not a fuse blowing, or the problem would persist.
Sorry if my info doesn't help much. GL with your Headlight issue.
#9 ·
Stephen,
Thank you,
Founding Member/Moderator
Save
