Hi, I know that the whole balance shaft sprocket issue is well covered but my issue doesn't seem to fit so I'd be interested if anyone else has had the following?
Recently the EML came on with Camshaft Position B Sensor failure bank 1. I swapped the sensor over to the other bank and the reset the code. It came back after driving for about 15 minutes with the same code, so I put a new solenoid in and reset the code again.
After a while the Sensor A code came up........ New solenoid on that as well and reset the code.
I drove it for about 50 miles and no codes. Turned off the ignition and when it started up again both sensor codes came up. I reset the codes and they stayed off for the return journey. Got home, turned it off and re-started it, codes came back........
So, any ideas what would cause the codes to only come on at the second starting of the engine? Is it just possessed??
