Bosch battery
3.5K views 16 replies 10 participants last post by  Delucas
#1 ·
Hello everyone -
Need a bit of guidance please. I need to change by SLK 200 / R171 battery asap.
After doing some research it seems that the below battery is compatible with my car (part no. A0035417301); furthermore, battery has the same specs as my current original Mercedes’ battery | 12v 74Ah 680A
I called Mercedes directly and battery price is double with them …
Do you have any compatibility or performance concerns with this Bosch battery?
Thank you in advance,
Ricardo
#3 ·
IF purchasing at a local store then test, or get them to test before buying (some sit on the shelf for a long time) and fully charge before fitting (amazing how many are not fully charged when bought from stores.
I presume you do not have stop/start from the description? If you do have s/s then needs to be an agm battery.
Reactions: slk55amgbob
Save
#10 ·
Probably too late by now - but are you near a Halfords? their batteries are pretty decent, and the 096 is on promo at the moment, and they generally have quite a fast turnover of batteries on popular lines like the 096 - so should be fairly fully charged straight off the shelf. Easier for warranty if things go wrong then as well - you can just take it back to a shop - Amazon needs it returning - and a battery isn't the easiest thing to return!
Halfords HB096 Lead Acid 12V Car Battery 3 Year Guarantee | Halfords UK
