I am struggling with an issue for some time. My car idles a little bit rough. No error code is thrown. This is especially noticeable if car is well warm up. I have already replaced O2 sensor 1 and cam sensor - I've got error codes indicating those 2 (not at the same time) and also I failed inspection due to emissions. After replacing those 2 parts errors went away and after replacing O2 emissions are now perfect. However, the rough idle remains, again no error codes this time. Recently I checked my MAF readings at idle. It fluctuates between 3.2 g/s and 3.6 g/s. Shouldn't be this value closer to like 2.3-2.6 g/s? Does it look like MAF sensor need replacement?
Also O2 sensors readings are strange. As far as I know O2 sensor before cat. readings should constantly fluctuate between 0 and 1V and readings for second sensor should be more or less constant. However, this is not the case here, especially at idle. O2 sensor 1 readings sometimes fluctuate but for several seconds can stay at the same level or change very little. For O2 sensor 2 the readings behave somewhat similar to O2 1 but fluctuates to lesser extent. Again, no error code is thrown. I'm guessing this might be related to bad MAF as well
