SLK P0015 P0012 P0022 P0025 Error DIY
11K views 0 replies 1 participant last post by  i860
#1 ·
If you have a cell and one of the error’s here is a short DIY
Parts:
Magnet 2720510177 x 4
O rig 0004661880 x 1
Transmission oil A001989240310 x 1l
All 3 magnets are easy to remove except for the p0025, to reach this one steering wheel reservoir needs to be remove. Removing the steering wheel reservoir is a bit trick.
First empty the reservoir and then the funny part removing the c clamp. I had to remove the wheel and the wheel arch in order to reach the clamp. I use a homemade hook removal tool to remove the clamp.
After removing the c clamp remove 3 screws from the steering wheel reservoir and just till the reservoir no need to remove the return hose. Make sure to replace the old gasket from the reservoir and steering pump.
Install in reverse order and fill with fresh fluid. To make sure that there is no air in the rack suspend the car and do 10 full turns let/right DO NO START YOUR ENGINE before bleeding procedure.
P0015 P0012 P0022 P0025 - Album on Imgur
