| | LinkBack (7) | Thread Tools |
| If you open the armrest to the side, it will reveal the place for the puck. The little connector will be quite obvious if it is there. There are pictures of the connector either on this forum or other SLK forums. If you search, you will probably see what it looks like. But as I said, if it is there, it will be very obvious. |
Country: Thanks: 54
Country: Thanks: 96
| This must be a US thing if the info they have given you is correct. I work for these guys and i have the documents in front of me that state what parts are required for any phone functionality at all. If you do get all the control modules included with the pre-wire then you guys are very lucky. in2dwww, maybe somebody will chime in before but if not let me know what you find when you install the puck would you please mate thats one thing about the US models they do tend to get better equipment packs the EU ones are stupid
| | #5 (permalink) | |
Country: Thanks: 377
Below is a photo of the central console cover lifted up and showing the larger lower compartment. Notice the lower 1/5 is actually a cover for something with a small notch. ![]() Pull out the rectangular cover and this is what I see: ![]() Close up of the wiring (is this for the bluetooth? If so, what additional kit need to be purchased and installed before the puck? Does one remove the 4 small screws and just thread the wires to the upper chamber?)
Vehicle: SLK55 2006
Country: Thanks: 24
| you must install the phone cradle and connect to that cable there, and possibly need to connect the mic in the trunk, and then the puck installs into the cradle. |
| | #7 (permalink) | |
Country: Thanks: 54
Are these pictures the actual pre-wiring for the factory MB Bluetooth? Are all SLKs pre-wired? I'm still confused with pre-wiring and what additional pieces are required to completed the system. Microphone installation, puck in center console, additional hardware in trunk? Once all the pieces are in place, will it fully integrate with the Command Nav display? Anyone know the cost for the additional hardware? THANKS!
| | #8 (permalink) | |
| Elite SLK World Member Join Date: Jan 2007
From my calls to AWS, the pre-wired SLK's have everything, mic, wires, etc. All we need to do is buy a cralde and a phone. So I already have the BT puck and it is supposed to replace the phone cradle. But the puck clips into something. AWS says that there is a "dust cover" in the center armrest (the small compartment that you access from tilting the armest to the LEFT or RIGHT, NOT UP). Under this dust cover should be the wire that the BT puck or phone craddle plugs into. I'm not sure if removing the dust cover is a permanent thing or not... does that plastic piece break away from its molding to pop out? Because of this fear, I'm not going to check this with some new car on the lot. From the pictures I see in this thread, the end of that wire looks like the actual clip for the BT puck and cradle. So it could just be a matter of threading that wire through the dust cover in the top half of the armrest. I'm going to get a pick of the clip for the BT puck in my E350, so that we can compare setups. From what I recall, the BT puck was designed to allow us MB owners to simply "add" the phone to our next MB simply by taking the puck out of one car and into the next. For example, if you lease a MB, your next MB only needs toi be prewired. When you transfer the puck out of your old MB and into the new one, you now have the phone installed, without the ridiculous $2000 price tag. | |
| | #9 (permalink) |
| Here is what my E350 has.... First you will see an empty cradle, where the phone gets charges and connects to the car. The second photo shows the phone in the cradle. The third photo shows the back of the bluetooth puck. The fourth photo shows the cradle removed, and the puck in place. The fifth photo shows the "clip" that the phone cradle or the BT puck can pulg into. This is the clip that I am looking for on the SLK. Is this attached to any of the wiring, or somehow under the "dust cover" in the small portion of the center armrest? |
| | #10 (permalink) |
| From the photos, it looks like one has to buy the cradle/clip and thread/attach this to the wire located in the bowels of the upper chamber. I do not about the mic thing -- US models have Teleaid and one can talk to them via the mic installed in the base of the rear view mirror (located in the cockpit). I do not know if bluetooth set up uses the same mic. We need help from more knowledgeable individuals.
| | #11 (permalink) |
Country: Thanks: 96
| OK here is the info i have accurate as of today. Eddy, Thats the pre-wiring for the phone you can see the FAKRA antenna connection behind the data and power feed lines in the pics you posted. Don, Thats the OEM pre-wire to complete the kit you need the cradle for the console, hardware in the trunk both the "core" and "completer" kits are required to enable the phone and a mic array once they are installed and coded the system will fully integrate with COMAND and the IC. in2dwww, For your model year there is a certain amount of guess work involved because the tech docs are not all finalized but if its the same as the 05,06 and 07 MY's then you will not be able to use the phone right from the get go you will have the same as Eddy's car and will need hardware to enable it. The plastic cover snaps out so don't try it on cars on the lot it will be very messy indeed, as you can see from Eddy's pics and as you correctly point out the cradle connects to those sockets that harness then leads into the trunk where the control units are required for all the model years up to 08 and possibly for 08 also. Do you have a VIN for your car yet so i can run it for you?
| | #12 (permalink) |
Country: Thanks: 96
| Eddy and Don, you will need the core kit that consists of the control modules and the linear compensator. Part number - BQ6820955 And the completer kit that has bracket and adapters for the SLK. Part number - BQ6820915 You might also need the Mic Array PN - BQ4820122
| | #13 (permalink) | |
The Bluetooth phone will work with the TeleAid mics. The wiring harness in the trunk is connected to those by default. When you connect up the Bluetooth phone, you have to unplug a connection in the trunk and connect it to the noise cancelling mics that are also in the overhead console. (or at least they are supposed to be there, but several of us with phone pre-wiring had no extra mics in there and the dealer had to add them in. Just a matter of opening the console up and plugging in the mics.) But the phone will work with just the TeleAid mics. | |
| | #14 (permalink) |
Country: Thanks: 96
| Its interesting that the latest TSB for this now says to add the Mic Array so it would appear that the latest models are coming off of the line without them installed and this is what is wanted by the factory. It never used to be like that they where in automatically however it looks like just the TeleAid mics are now fitted
| | #15 (permalink) |
| SLK World Member Join Date: Nov 2006 Location: New jersey
Vehicle: 2006 E 350
| I have been following this and many other posts concerning if the SLK is pre wired for a phone (bluetooth), I also have the wires visible in the console and wondering if any of you followed up with a installation. I have gotten so many conflicting views and prices for a install, Im hoping someone has a difinitive answer. Thanks guys, great posts |
| | #16 (permalink) |
Country: Thanks: 96
| If you have the pre-wire option on the car then the PN#'s i posted will complete the kit for you. I am positive.
| | #17 (permalink) |
| From MBUSA: if you order the car with the Hands-Free Communication System installed at the factory, it is a $925 option, i.e., the core kit, completer kit and mic array are installed at the factory. If you install the components later after delivery, the dealer will charge more than $1,000 (close to $2000 according to one salesman).
| | #18 (permalink) | |
Country: Thanks: 96
Thats mark up for ya
