Need help with DNX6160 Kenwood wiring harness - Mercedes Benz SLK Forum
Where to get R171 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
#1 Old 06-12-2013
Ninja650R's Avatar
Vehicle: 2006 SLK350 Diamond Silver
Other Toys: 2007 Candy Red VFR800A
that is...I need a wiring harness that will work for my 2006 SLK350 with Harmon Kardon system and Command.
Anyway - I bought a used dnx6160 that has a harness, but I would have to connect all the wires to the correct wires at the other end as the wires are cut between the two endpoints. It came out of an Altima, so one end of the harness is probably wrong anyway. I simply have no clue how to wire everything without a pre-wired harness to BOTH ends. I'd love to just buy a wiring harness to connect everything.
I plan to get a backup camera too. I have the SWI for steering controls, but some of the wires are cut too, so I'm not sure if I'll be able to use that either. I have the other stuff like GPS antenna, Ipod connector, USB connector - and those look okay to me.
If you have any ideas as to where to find the exact wiring harness that I need, please help. I've done numerous searches, and I think I'm getting more confused as I go.
TIA for any ideas you can provide.
Edit: BTW - I submitted a request to www.Kenwoodusa.com support to see if they have anything like this.
Ninja650R is offline
#2 Old 06-12-2013
Vehicle: 05 slk350
Other Toys: 95 eclipse gst, 99 expedition, 02 accord, 02 maxima
Why don't you try buying one of those harness that you connect the wires to the radio and then just plug into your stock radio harness this way you don't need to cut anything.
I forgot what they are called.
it's called an adapter harness which I just looked up on ebay
http://www.ebay.com/itm/CAR-STEREO-C...b2461e&vxp=mtr
tnsr35 is offline
#3 Old 06-13-2013
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
Not quite as straight forward as that...
I'm assuming the Kenwood has ISO connectors (tried to check a manual but the site I was using was unavailable...) - that's pretty straight forward.
As you have the HK system, the speakers are driven by an amplifier located in the front electronics bay (under the passengers feet), and the speakers have no external filtering / crossover network
As you can't connect the Kenwood to the HK amp (it's a fibre connection), you'll need to do a couple of things..
Get a lead (from somewhere like Command Online, or Frank at Cabldaviko) that goes from the Kenwood's ISO connector to the connector that the HK amp plugs into
Fit chokes / capacitors to the speakers and re-wire them so the correct drivers are fed by the correct channels of your head unit ( like the wiring would be if you had an Audio 20 instead of Command) OR by external active crossovers and enough channels of amplification to drive the 11 HK speakers (I believe thay are driven by 8 channels of amplification) - neither of these is trivial, made slightly more awkward due to the low impedance drivers used in the HK setup - you need to ensure that your headunit and any amps are happy with a 2 ohm load
You'll also need adapters for power, ground and CANBUS (for the steering wheel controls), antenna power etc etc
The good news is all of these can be got from the connector into the Audio Gateway (HK AMP) - you'll need to do some work to a harness or adapter if you can get one depending on how you plan to drive the speakers - the wiring diagrams detail which wire goes where and what colours they are....
You ma also be able to use the stock microphones - you'll probably be better off using your own GPS puck and mounting it either under the centre airvent or in the stock location behind the rear view mirror (search the forum for info about this)
It's all do-able, a bit fiddly but you should be able to get good results with the right amplification...
Sean
PS – check out https://www.slkworld.com/united-kingdom-region/31725-east-midlands-rabbit-chase.html for info on the possible East Midlands ‘Rabbit Chase”
Mods so far...
Airscarf Retro-fit https://www.slkworld.com/general-modifications-r171/27470-project-airscarf-starts-here.html
Alpine double-din touchscreen head unit with Bluetooth, Nav, DVD, reverse camera and iPod with a ‘Small’ sub in the boot
https://www.slkworld.com/slk-r171-general-discussion/26915-amplifier-location.html
Mercedes Genuine rear Windscreen
https://www.slkworld.com/general-modifications-r171/32951-new-windscreen-one-back.html
Display& steering wheel integration for the head unit.
Digital Climate control panel, Sun sensor and Pollution sensor fully working
https://www.slkworld.com/general-modifications-r171/30240-climatronic-retrofit-digital-climate-control.html
Hat-shelf mounted solar charging panel
Rain Sensor for Auto-wipe retrofit
Various coding changes to the Instrument cluster – see below
AMG Aluminium gear change paddles instead of the buttons
https://www.slkworld.com/general-modifications-r171/31587-amg-aluminuum-gear-change-paddle-retrofit.html
Facelift SLK Antenna https://www.slkworld.com/general-modifications-r171/32272-facelift-antenna-tick-otherwise-known-two-minute-mod.html
Harman Kardon speaker upgrade – All 11 !!
https://www.slkworld.com/general-modifications-r171/31530-hk-speaker-upgrade.html
Custom dimming LED DRL’s https://www.slkworld.com/general-modifications-r171/32992-looking-drls.html
LED’s… in various places…[x] - Map…[x] – Dome…l [x] – Number plate…[x] –Side…[x] – Puddle https://www.slkworld.com/general-modifications-r171/33120-leds-were-all.html
Full blown TPMS…
https://www.slkworld.com/general-modifications-r171/33263-tpms-retrofit-its-started.html
Auto Dimming rearview mirror with integrated GPS Speed Camera detector BEHIND the glass….
https://www.slkworld.com/general-modifications-r171/35096-my-solution-dimming-interior-mirror-look-away-if-you-dont-want-see-things-getting-cut-up.html
Power Folding mirrors… https://www.slkworld.com/general-modifications-r171/33942-folding-mirrors-making-start.html
Designo style Alcantara head lining and various other bits….
Johns 3rd brake light gizmo
https://www.slkworld.com/general-modifications-r171/15456-johns-3rd-brake-light-adapter.html
Mods in progress
Parktronic retrofit – nearly all the bits are here….. Just need the main loom now….
…soon this section will be empty …!
Mods on the wish list
Maybe a Smarttop.... maybe the ROTM fairy will be good to me…!
Illuminated Sills – I have a cunning plan…
Coding Mods… https://www.slkworld.com/slk-r171-general-discussion/31073-my-adventrures-star-diag.html
[x] - Enable those pesky phone buttons on the steering wheel - FINALLY DONE - WOOHOO
[x] - Enable Auto-wipe – done
[x] - Add temperature display to the lower MFD - done
[x] - Enable tyre pressure Loss Warning - done
[x] - Enabled Folding mirrors – done
[x] - Enable Gallons Remaining in the MFD – done
[x] - Enable Cornering Fogs - done
[x] - Enable both rear fogs - done
[x] - Enable Alarm 'chirping' – done
[x] - Enable TPMS display in the upper MFD – done
[ ] - Enable Highline TPMS – proving tricky!!, but we have some great brains on the case….
Seanhump is offline
#4 Old 06-13-2013
Ninja650R's Avatar
Holy smoke. I thought this might be more plug-n-play, but that just went so far over my limited knowledge about electronics, that I am totally bewildered as to how to connect all of this stuff.
Looks like I'll be selling this on Ebay. No way can I possibly learn all of that stuff in my lifetime.
Thanks - I'll probably stop by an electronics store where they install stuff like this and see if any of this is even possible within a reasonable price. I don't want to put a 1000 bucks into this project.
And I checked on all of those adapters. I couldn't find one for 2006 models that matches what I had in mind.
Thanks again for all of that info. Too bad I can't understand all of that stuff.
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
Installing Trunk Wiring Harness Philly Bob SLK R171 Class DIY 16 12-09-2012 07:28 PM
Where to find radio wiring harness for US SLK? tandem Where to get R171 SLK Items 7 10-09-2012 03:32 PM
Such thing as wiring harness with rca outputs for aftermarket amp? sunnysingh General Modifications R171 0 08-13-2012 10:14 PM
