Driver's seat shell on the Dawg - Mercedes Benz SLK Forum
Where to get R171 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
 9Likes
  • 1 Post By jbanks15
  • 1 Post By fastdawg1
  • 1 Post By Windinmyhair
  • 1 Post By HUWhitaker
  • 1 Post By G0RSQ
#1 Old 03-28-2018
fastdawg
fastdawg1's Avatar
Vehicle: 2007 SLK350 6spd
Quoted: 94 Post(s)
The seat shell on the drivers side (US models) closest to the door is cracked vertically. I'm looking for a part number and or replacement part for it without buying a whole new seat. Did some searching but not coming up with anything definitive. I'm talking about the silver/grey shell, not the dark cover on the back. From what I'm seeing in some illustrated parts breakdowns they are separate units. I haven't went to the dealer yet on this, but I figure it would be pricey. Any help is appreciated. Thanks.
fastdawg1 is offline
#2 Old 03-28-2018
Quoted: 6450 Post(s)
So i have to dig up your vin Bob? Is that what your are saying?
fastdawg1 likes this.
#3 Old 03-28-2018
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
Actually I'm at work, but found the old data sheet, so here it is:
Identification number: WDB1714561F155625 1
VIN: WDBWK56F87F155625
#4 Old 03-28-2018
you can look it up yourself or i will
https://slk-links.neocities.org/
#5 Old 03-28-2018
Here ya go @fastdawg1
#6 Old 03-28-2018
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
Yeah, thanks Jeff, I got there, then started looking up on the internet, that long crack is going to cost me about 1K no matter where. I did find an actual seat for sale on Ebay, even the same color but not in as good as shape as mine for 264 plus 100 dollars shipping, but you really don't know about the shell until you get it apart, so it's a bit risky. I'd like to just find the shell used, I could be fine with that. But thanks as having that part number of: 171-911-00-06-9778 is a big help. Other than taking the seat out, it doesn't look like it should be really hard to do.
#7 Old 03-28-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 329 Post(s)
Could the shell be repaired in a similar way to plastic bumpers?
Windinmyhair is online now
#8 Old 03-28-2018
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
I'd be surprised, it runs along the most of the side curve with the back plate, looks like a stress point that would be under a lot of pressure going in and out of the car. I've thought about that, even to the point of taking it to an upholstery shop and having them take a look at it, but it would surprise me if they said yes.
#9 Old 03-28-2018
Quoted: 329 Post(s)
What would it cost to have a GRP replacement made up using the existing as a pattern or is it too complex a shape?
#10 Old 03-30-2018
Roodster's Avatar
Vehicle: smart Roadster, 2002 SLK 200K, replaced by 2004 SLK350
Other Toys: 1992 Ducati 900SS, 2014 Ducati Hypermotard SP 821
Quoted: 50 Post(s)
I have the same (cosmetic) "problem..."
Is it easy to take that trim off the seat?
I would like to repair it with epoxy resin and glass fibre.
Roodster is offline
#11 Old 03-30-2018
HUWhitaker's Avatar
Vehicle: 2006 SLK55 Fire Opal red/Beige
Quoted: 61 Post(s)
I purchased my '06 SLK55 with the same issue. No doubt that factored into the great deal I got on it. The material is a magnesium-aluminum alloy and does not provide much adhesion for epoxy (first-hand experience). From what I read, welding is a problem also. My solution was to buy a donor seat back on Ebay for $175. Now all I need to get is that special tool called 'a-round-tuit'.
HUWhitaker is offline
The Following User Says Thank You to HUWhitaker For This Useful Post:
#12 Old 04-02-2018
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
Yeah, I've found a donor seat too, exact color and all, unfortunately it's not in great shape leather wise, but all I need is the shell. It's 264 plus 100 bucks shipping so I'm thinking about it. Thanks.
HUWhitaker likes this.
#13 Old 04-02-2018
G0RSQ's Avatar
Quoted: 151 Post(s)
If the shell is a magnesium alloy it probably can be welded, though not an amateur DIY proposition!
have you tried calling around local engineering/fabrication companies?
I have found some very friendly and helpful engineering companies in the past if you approach them nicely.
G0RSQ is offline
The Following User Says Thank You to G0RSQ For This Useful Post:
#14 Old 04-03-2018
fastdawg
fastdawg1's Avatar
Quoted: 94 Post(s)
It's a thought, but no, haven't gone that way yet. Time constraints probably will not allow that as an option between the searching and arrangements. Probably a donor seat is the more likely way I'm going. But it is a thought if I get some time.
#15 Old 04-03-2018
Just a regular guy
Gmonslk's Avatar
Vehicle: 2007 SLK 280
Other Toys: 2015 Tacoma Prerunner SR5 (towing and shuttle activities) 2015 Lund fishing boat
Quoted: 30 Post(s)
AMG time 😬...........
Living a dream..........
Part 2.
Gmonslk is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
Lower heated seat element milesy_boy SLK R171 General Discussion 228 01-25-2019 08:53 AM
