UK - Oil extractor pump - Mercedes Benz SLK Forum
Where to get R171 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
  • 1 Post By nimbusgb
#1 Old 07-29-2017
nimbusgb's Avatar
Quoted: 249 Post(s)
If you are going to change gearbox or engine oil a suction type pump is a godsend.
Pela is the best available in my book. I've had one for about 10 years and it still works great. ( it's a little dirtier than it used to be though )
i see they are on sale in the UK for about 35. a good price.
https://www.mailspeedmarine.com/oil-...ump-37774.html
No connection just in case people are interested.
( I've seen these advertised on eBay for 111! LOL )
55russamg likes this.
nimbusgb is offline
#2 Old 07-29-2017
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 327 Post(s)
Thumbs up
same one I use , great bit of kit
frogfoot is offline
#3 Old 07-29-2017
LeonardoDaBenz's Avatar
Quoted: 1007 Post(s)
For us on amaz . ca . Not really a fair currency conversion though:
LEN
(Moderator)
I cant give you a sure-fire formula for success, but I can give
you a formula for failure: try to please everybody all the time.
Herbert Bayard Swope
LeonardoDaBenz is online now
#4 Old 07-29-2017
Ray1nl's Avatar
Vehicle: 2008 SLK 55 AMG White with performance package
Quoted: 17 Post(s)
I have used this one for various purposes to extract oil from gear boxes and have used this as well on my previous 2000 SLK 230 extracting the oil thru the dipstick tube.
It works great and is available at a reasonable low price on Amazon.
Air Power America 2000 LiquiVac Oil Changing System for Large 8 quart capacity Engine $51.75 they also have them for smaller 3.5 quarts capacity which runs at $38.88
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Ray1nl is offline
#5 Old 11-08-2017
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
Check these out:
SilverSLK2010 is offline
#6 Old 02-16-2018
Slkworm's Avatar
Vehicle: Slk 200k 171, 2010, silver with sports pack
Other Toys: ASTRA VXR RACING LTD, RENAULT Captur
Chats: 2
Quoted: 48 Post(s)
Does it come with plastic pipes ect
Slkworm is offline
#7 Old 02-16-2018
Moderator/RoTMorganiser
Quoted: 2188 Post(s)
Click the link: https://www.mailspeedmarine.com/oil-...ump-37774.html
It lists what you get and how to use it.
#8 Old 04-08-2018
Slkworm's Avatar
Chats: 2
Quoted: 48 Post(s)
If you use the pump to say extract oil from auto transmission, can it be refilled via the dip stick tube ?
Slkworm is offline
#9 Old 04-12-2018
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 525 Post(s)
Depends which transmission you have but generally if you can suck via a dipstick tube, you can fill by it too.
Terminal is offline
#10 Old 06-13-2018
Vehicle: '05 171 SLK 55 AMG
Quoted: 53 Post(s)
You need to take the pan off to change filter anyway.
I imagine without removing the filter that a lot of fluid would remain within the box, would be interesting to see how much came out with it still sealed - might be completely wrong.
Topaz is offline
#11 Old 06-13-2018
Elmer Fudd's Avatar
Quoted: 189 Post(s)
If you are 7gtronic
no transmission dipstick tube. Level measurement by the overflow method after undoing the drain plug. Filling is by pumping fluid up into the drain plug orifice. I only know 'cos I've just done it to my S211. You can get most of the fluid out of the pan if you dislodge the overflow pipe, but you will have to dismount the pan to remount the tube. Not a problem if you are doing the filter. You will need a new gasket, and most importantly, the new pan mounting bolts.
I'll stop now. No, i won't. I used a 12v extraction pump ( Lidl, 13.99) to pump the new fluid up into the transmission. A bit fiddly, but not exactly hard work.
Elmer Fudd is offline
#12 Old 06-22-2018
Quoted: 53 Post(s)
You're spot on. I've been out the game to long!
Topaz is offline
#13 Old 06-23-2018
Elmer Fudd's Avatar
Quoted: 189 Post(s)
if you do the full monty
including torque converter drain, and flush the cooler, you will need about 14 litres of fluid ( remember, you have to overfill it to get it to drain to the correct level) I bought 20 litres of Fuchs 4134 Transmission fluid from Clarke Oil on their ebay site. 92 . and it suits all my other Mb transmissions as well.
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
DIY manual transmission and diff oil change SeanB SLK R171 Class DIY 33 08-02-2018 03:52 PM
