R171 Cabin Fan UK. - Mercedes Benz SLK Forum
Where to get R171 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
 4Likes
  • 1 Post By WarwickThumbNT
  • 2 Post By Bob Costa
  • 1 Post By mazzbob
#1 Old 06-14-2016
Quoted: 37 Post(s)
R171 Cabin Fan UK.
Hi been looking to find a reasonably priced cabin fan for my SLK350. tried the usual google searches and e-bay. Has anyone managed to find a cheap supplier?
I'm in no rush as the fan still works but is quite noisy at high speed.
Thanks Mark
Mark999 is offline
#2 Old 06-14-2016
Vehicle: R171 2004 200 KOMPRESSOR andradite green
Quoted: 73 Post(s)
If it's not hard to get access to it a little bit of proper grease (not WD-40!!) can make huge difference and give you more time. I just checked yt and it seems to be 20 min job to get the fan on the table.
racing_green is offline
#3 Old 06-14-2016
Vehicle: 2005 SLK 350
Other Toys: H20 V-Dubs, MK1s
Quoted: 410 Post(s)
I would try "3 in 1" brand oil, specific for electric motors. I've used it in the past and a noisy fan shaped right up. You may have to live the smell inside for a little while but it's quicker and cheaper than replacing the fan.
Roxanne7169 is offline
#4 Old 06-14-2016
Vehicle: GONE - 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heat, Light, Comfort, Premium, Ent. w/Nav
Other Toys: 1967 Chevrolet El Camino.2015 Charger R/T R&T B5 Blue
Quoted: 213 Post(s)
Thanks Mark
Is it bearing noise or another sound. Don't rule out something stuck in there that might be hitting the fan.
Pioneer4x4 is offline
#5 Old 06-14-2016
Vehicle: 2009 SLK280 SPORT PACK
Other Toys: 2016 Indian Scout 2011 Triumph Thruxton 2006 E class 280 CDI SPORT
Dry leaves?
Akaulaking is offline
#6 Old 06-14-2016
Quoted: 37 Post(s)
Hi Thanks for your replies. I had it checked out by my indie when I had the instrument cluster repaired, apparently there was no debris. But I'll check myself.
To me it sounds like the fan is catching on something.
Cheers Mark
Mark999 is offline
#7 Old 06-14-2016
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 892 Post(s)
Thanks Mark
Hi Mark
Call those guys :
Mercedes Parts - Mercedes Spares from Dronsfields, a Leading UK Breaker
i860 is online now
#8 Old 06-14-2016
Star/DAS Registered Owner
Quoted: 499 Post(s)
Cheers Mark
You can access the blower from both sides. The top through the battery compartment and the bottom by removing the inside air filter. May want to just pull it out and do a thorough inspection of it.
mchild is offline
#9 Old 06-26-2016
WarwickThumbNT's Avatar
Vehicle: 2005 SLK200 Obsidian Black Beige leather, Vavona wood. Airscarf, Comand, heated seats...Smart top :)
Other Toys: Various basses including Warwick, Fender and Electric Upright Bass
Quoted: 159 Post(s)
Thumbs up
<iframe width="560" height="315" src="https://www.youtube.com/embed/HrUnr_hhEl8" frameborder="0" allowfullscreen></iframe>
This guy deserves our thanks
WarwickThumbNT is offline
The Following User Says Thank You to WarwickThumbNT For This Useful Post:
#10 Old 06-26-2016
Quoted: 159 Post(s)
Just a shame I'm useless at posting vids.....
Pres likes this.
#11 Old 06-26-2016
Quoted: 213 Post(s)
The Following 2 Users Say Thank You to Pioneer4x4 For This Useful Post:
#12 Old 12-04-2016
Duckbay's Avatar
Vehicle: 2005 Jasper Blue 350s SLK Auto
Quoted: 16 Post(s)
Thanks to the guy for that vid as my fan making a loud noise at 1 & 2 setting but quietens as the fan speeds up. Took it all apart today using the vid and its obvious someone has done that previously as the awkwards screws to get to were missing. Sanded the base of the compartment where there were some scratches, cleaned the base of the propellor part of the fan, oiled and re-assembled. All pretty quiet now but the fan was in pretty poor shape so will need a replacement maybe in the future.
Worst part was trying to re-locate the fan compartment in the correct place when re-assembling. Eventually sorted by putting in the centre screw first, then the yellow clip as you only have to hold up the back of the unit in the footwell to locate the other screws. If my knees and back were not messed up before that job they are now.
Duckbay is offline
#13 Old 12-24-2016
Vehicle: SLK 350 2006 29000 miles
Send a message via Skype™ to D G Ford
I had to replace my cabin fan about 6 months ago for SLK350 for being noisy. Like yours mine looked pretty bad and I did all the cleaning oiling etc but it did not make much difference so I bit the bullet and decided to replace it. I looked hard (eBay, reconditioned,deals breakers yards etc)for a good price but there was no choice other than to buy a new one at the full price. Anyhow fitting it was a bit awkward but straightforward and it is now beautifully quiet.
D G Ford is offline
#14 Old 03-26-2017
Vehicle: 2005 R171 SLK350
I ended up replacing mine about 6 months ago after it went from making intermittent screeching noises to being a steady screech. I ended ordering a new fan on Amazon. The regular cost locally(US) was about $600 as I recall. The one I got was shipped from Latvia(I had to look that one up on the map) but was only about $120. I was nervous about ordering from so far away but the fan that arrived was a good fit and works as good as new(because it was a new item). I did need to trim the fan blades a tiny bit with a Dremmel to make it slightly more quiet. Also you should note that it is a tight fit accessing this project. Expect to have your head, arms and upper torso jammed up pretty tight in that passenger side footwell as it's a pretty tight fit for anyone of a large build. Good luck, I hope this helped!!
https://www.amazon.com/Valeo-715247-...s=blower+motor
Above is the link for the seller I used. I noticed that they were listing thier items on Ebay and Amazon.(Musterbuild)
LIL DON SLK and Çooky like this.
Bob Costa is offline
#15 Old 03-26-2017
Quoted: 6432 Post(s)
First please update your location and vehicle (Put Looking!)(year?: 1996-2017, model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#16 Old 05-15-2017
Beastmaster's Avatar
Vehicle: SLK 200 2005
I had a similar loud rumble noise from the fan when the settings were on high, so rather than take everything apart I used a lithium spray grease with a straw and went at the fan through the battery compartment. A few well aimed squirts did the job and now my fan runs smoothly. I do this now as part of my monthly maintenance program to keep things running free. It's certainly worth the little effort for a big reward.
Beastmaster is offline
#17 Old 05-22-2017
mazzbob's Avatar
Vehicle: 2005 SLK350, Silver, 6 Speed Manual
Other Toys: cannondale road bike
Quoted: 23 Post(s)
https://www.slkworld.com/slk-r171-cla...l?nojs=1#links
other blower fixes that could help.
dbgrn likes this.
mazzbob is offline
The Following User Says Thank You to mazzbob For This Useful Post:
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
New R171 163hp or newer R171 184hp? difot New Members Introduce Yourself Here 12 02-02-2018 08:45 AM
blower fan not working 1997 slk 230 peteslk SLK R170 General Discussion 56 08-22-2016 08:06 AM
Weak Radiator Fan. bakon SLK R170 General Discussion 20 03-29-2016 09:56 PM
