replacement speakers - Mercedes Benz SLK Forum
Where to get R171 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
  • 1 Post By jbanks15
  • 1 Post By Seanhump
#1 Old 03-15-2014
Vehicle: 2005 SLK 350
Other Toys: Bikes & Jet ski
Hello,
it's been some time sice I last posted.
Where can I purchase replacement speakers.
I need to replace the speakers located in the rop center console and the speakers located by the seatbelt.
They start to crackle at high volume. I think they are blown.
tomasito is offline
#2 Old 03-15-2014
Quoted: 6415 Post(s)
Slkstore is back open n I saw a center speaker there
vinnypt likes this.
#3 Old 03-15-2014
Sent from AutoGuide.com App
tomasito is offline
#4 Old 04-25-2014
vinnypt's Avatar
Vehicle: 2006 Mercedes SLK 200 Kompressor
Other Toys: Audi A6 V6 2.5L 203 BHp
Quoted: 46 Post(s)
Send a message via Skype™ to vinnypt
Can I upgrade my OEM Speaker System to a better one changing only the Speakers ?
vinnypt is offline
#5 Old 04-25-2014
if your current speakers are old/defective then yes. what audio system is in your car? audio 20 or 50 or hk? get your datacard to find out.
#6 Old 06-03-2014
vinnypt's Avatar
Quoted: 46 Post(s)
I have a AUDIO 20.
vinnypt is offline
#7 Old 06-03-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Another doubt that I have is:
If I change AUDIO 20 to a Aftermarket Stereo can I Use the FADER Control ?
vinnypt is offline
#8 Old 06-03-2014
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Vinny,
The large door speakers in the SLK are a combination setup of a mid and a tweeter with an integral crossover. (See pic) The only replacement "in kind" I have seen done was using Hertz Space 8's because they are so shallow. Here's a link to a previous install.
https://www.slkworld.com/general-modi...ete-w-pix.html
With you being in Europe you have a shot at getting the Hertz speakers, but they are pricey. Interestingly enough there are several comments in the aftermarket head threads that refer to "better sound" after replacing the A20.
Best Wishes
Gene
REB_TN_06 is offline
#9 Old 06-03-2014
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 423 Post(s)
An aftermarket headunit does make the stock speakers sound better, and you benefit from a fader control too, but not in the conventional sense.
The front channels drive the mids and tweeters (plus the centre) that are in the doors, and the rear channel drives the door bass drivers AND the rear speakers near the seatbelts.
The rears are more of a 'presence' speaker and are not full range.
I'd try Ebay for used - they do appear now and then, or a main dealer - you'd be surprised with the main dealer costs - not as expensive as you may think.
I upgraded to Harmon Kardon all round and may still have the old rears and centre speaker, but shipping to SF may prove more costly than buying them ..
Sean
vinnypt likes this.
Seanhump is offline
#10 Old 06-04-2014
Beekster's Avatar
Quoted: 164 Post(s)
I'm sure that this will be deemed a silly question, but I'll ask it anyway: If the car was built with Audio20, is there even a wiring harness present at the location of the HK rear speakers flanking the console extension where the first aid kit resides? Or would a wiring harness have to be retrofitted there? I've upgraded to an Alpine head unit and the stock door speakers do indeed sound worlds better, but this has me pondering the addition of the little rear speakers. I'm sure the head unit would drive them.
Beekster is offline
#11 Old 06-04-2014
REB_TN_06's Avatar
Beekster,
If I get your question, you are asking if the H-K wiring harness was installed into your car even though the H-K system wasn't because of your A20 HU.
The uninformed answer is I doubt it, but if you want you can register (free) for the EPC tool, put in your VIN#, and it will tell you what wiring harness(s) are present in your car.
There's a thread on here that shows you how to register.
Best Wishes,
Gene
#12 Old 06-04-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Sean
Cool,
Thanks.
vinnypt is offline
#13 Old 06-04-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Originally Posted by REB_TN_06 View Post
Vinny,
Best Wishes
Thanks, I'll try to get a good deal on a new HU !
vinnypt is offline
#14 Old 06-04-2014
Seanhump's Avatar
Quoted: 423 Post(s)
It won't be installed - the A20 headunits didn't have the 'extra' two speakers.
If it was, it would end up in the front electronics bay where the HK amp would live ...
It's a pretty straight forward job to add the speakers and a harness - I have them hooked into the same circuit as the 'outer' rears, and after some careful fiddling I managed to get an impedance that worked.
The tricky bit is drilling out the covers ... (unless you buy a HK cover for the centre armrest)
Sean
Seanhump is offline
#15 Old 06-04-2014
Vehicle: slk 200 manual/sport f/l 2008
In ebay you could find many harman kardon speakers and harman packages!!
Also they are available in the forum in lower prices!
Please ask!!
stefan is offline
#16 Old 06-11-2014
vinnypt's Avatar
Quoted: 46 Post(s)
Sean
I have buyed a new S100 HU. I'm waiting for it near this end of the month.
Do you thing I will get great gains if I replace the OEM speakers to?
vinnypt is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R171 SLK Class Cars > Where to get R171 SLK Items
2005 SLK350 w/ A20 - where are the speakers?? SLKDawg SLK R171 General Discussion 6 05-26-2017 02:35 PM
[Help] Looking for Speakers! [Pics Included] TimPonken SLK R170 General Discussion 3 04-02-2012 08:45 AM
stock speakers max volume question zymotix3 General Modifications R171 2 02-21-2012 09:44 AM
Upgrading crappy speakers linuxpro General Discussion 1 12-10-2008 04:35 AM
Installing speakers - how? SteveSLK06 General Modifications R171 7 07-17-2008 03:09 AM
