SLK230 Headlight Washer Jets - Mercedes Benz SLK Forum
Where to get R170 SLK Items Ask where to locate or buy NEW items for your SLK. No Commerical Posts Allowed. Please note you will require a minimum of 10 posts to create a thread here.
 4Likes
  • 1 Post By Landy109s2a
  • 2 Post By savcom
  • 1 Post By savcom
#1 Old 04-11-2018
Vehicle: SLK230K Blue - 352. UK Reg.2000. Facelift. 94,000 miles
Other Toys: 1964 Landrover s2a LWB. 1974 Jensen Healey. 1964 Singer Vogue.
Send a message via AIM to Landy109s2a
Availability and price of a pair of SLK 230K Headlight Washer Jets for a 2000 Reg.UK vehicle. I have searched various sites.Plenty of washers.None that look like the ones fitted to my SLK. Have they
been replaced by an updated type ?
LIL DON SLK likes this.
Landy109s2a is offline
#2 Old 04-11-2018
Moderator/RoTMorganiser
Quoted: 2137 Post(s)
Welcome to SLKWorld.com: The #1 Mercedes-Benz SLK Forum!
First please update your location & vehicle (model?: 32, 43, 200, 230, 250, 280, 300,320,350,55) in your profile as it helps the members answer your questions which usually are based on that information if you haven’t. This takes about 30 seconds to do.
Follow exactly to update: ‘Usercp’ at the top of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘vehicle’. Info in your garage does not update your profile.
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. New Members Introduce Yourself Here - Mercedes Benz SLK Forum
#3 Old 04-12-2018
@Turdo2
@Livefreeordie
@efair
@savcom @Simon cliffe @devilman9050 @stu32
R170 experts are on their way.
Not forgetting:
#4 Old 04-12-2018
savcom's Avatar
Quoted: 599 Post(s)
What's wrong with your units? Not many headlamp washers were fitted, if I'm honest, but if they are then depending on what's wrong, like as not someone here would have found a fix. I stripped and cleaned mine which worked wonders (no further trouble) so give us some more info about your problem and we can try and help!
Avel Du and devilman9050 like this.
Also
Previous :
savcom is offline
#5 Old 04-13-2018
Morning all, thanks for reply. the problem is blocked jets.Water pressure from the pump,blows the jets off the plastic pipes.
The jets fitted look like sealed units.Are they repairable,and how do you take them apart ??
#6 Old 04-13-2018
Other Toys: Ginetta G32
Quoted: 92 Post(s)
I don't think they are repairable. If they are blocked can you not try and force water the wrong way with a tube on the top and hose pipe. Perhaps leave them soaking in some Milton overnight may help first and/or some thin wire to poke them clear. Dronsfield in Oldham break a lot of Mercedes and may have some good used items on the shelf.
stu32 is offline
#7 Old 04-13-2018
Vehicle: White 250d (2015)
Other Toys: Flexwing Microlight, Bike (CBF1000)
I hate headlight washers - they are such a PITA - and waste loads of water/screenwash.. last 3 cars i have had i took the relay out so they didn't work..
Andymackk is offline
#8 Old 04-13-2018
savcom's Avatar
Quoted: 599 Post(s)
You might be lucky - as I was - so I have linked the thread I wrote when I looked at mine:
https://www.slkworld.com/slk-r170-cla...er-nozzle.html
stu32 likes this.
Also
Previous :
savcom is offline
Go Back   Mercedes Benz SLK Forum > Mercedes Benz R170 SLK Class Cars > Where to get R170 SLK Items
A 'Who's Who' in SLKWorld.com Woolly New Members Introduce Yourself Here 5 1 Week Ago 07:42 AM
Headlight washer cover Blessed Again SLK R170 General Discussion 3 02-10-2015 02:37 PM
headlight washer question gonzosc1 SLK R170 General Discussion 11 02-03-2014 05:59 AM
Heater washer jets.. Seanhump SLK R171 General Discussion 6 02-04-2013 09:26 AM
