How often do you need to replace tires? - Mercedes Benz SLK Forum
#1 Old 07-27-2013
I have a 2012 SLK with 15k mikes, and the ride is loud....is it time to replace tires?
sullywdw is offline
#2 Old 07-27-2013
Quoted: 6496 Post(s)
#3 Old 07-27-2013
Depends on your model which please update in your profile with location
Recent post shows on our amg, replacing tires as early as 6500 miles and as for me, 10-15k
#4 Old 07-27-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
What Jeff said. With these tire specs (130 + MPH ) you can get all kinds of tread wear ratings, and like anything, you usually sacrifice handling for tread life. I measure tread depth with a gauge and replace when it gets down in the 3 range. Plenty of experience on the site on tires. Read on !
Best Wishes,
Gene
REB_TN_06 is offline
#5 Old 07-27-2013
Sadly Gregg has passed away
Gregg's Avatar
Vehicle: 2009 SLK 350
Chats: 5
Quoted: 17 Post(s)
Quite a few posts on the site have identified 10K miles as about the average rear tire replacement with front doing 2 to 3 times that mileage. Rears on Challenge lasted right at 10K miles.
Gregg is offline
#6 Old 07-27-2013
Check the tire tread depth with a gauge (across the 3 or 4 grooves), go with lowest (thinnest) reading. It should be above 3/32" or 3mm. Measure the tread depth on all four tires and shine a light and inspect the inner tire walls especially on the front tires.
See my experience: https://www.slkworld.com/tires-wheels...ide-walls.html
I normally have to replace the rear tires between 10-12K miles.
#7 Old 07-27-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Another big issue to consider is the age of the tire. Once your tires get to eight years or so, you might want to think about a change. I expect to have to replace mine well before they tread wears out. Some countries have an age limit on tires. There are also some interesting articles on the web about old tires. Here is one - http://rense.com/general82/timeb.htm
Len
1999 E300D 215,000 miles
sokoloff is offline
How long your rear tires last? topboxman AMGs 64 12-14-2014 12:59 PM
New Rear Tires for my SLK55 AMG today netmiami Tires, Wheels, Brakes & Suspension 5 03-24-2011 01:33 AM
New Tire surprise, recommendations ASAP Brian_74 Tires, Wheels, Brakes & Suspension 54 09-28-2009 12:09 AM
Help with Tires noregret4life SLK R171 General Discussion 43 03-31-2008 11:09 AM
