rear shocker removal ???? - Mercedes Benz SLK Forum
#1 Old 06-05-2013
peZonator's Avatar
Vehicle: slk 350 MY09
Quoted: 8 Post(s)
hey super SLK team
i have an slk MY09 slk 350
i am about to replace my rear shockers ,
my question is:
how do you get to the top nut assembly to remove the shock ?
do i need to remove all the trim on the inside if the boot
do i cut a small hole where the shocker mounts should be
if anyone has had experience in doing so or has found a thread to read, it would be greatly appreciated if you could share your knowledge
peZonator is offline
#2 Old 06-05-2013
Sadly Woolly has passed away
Vehicle: SLK350 MT
Chats: 1297
Quoted: 120 Post(s)
Originally Posted by peZonator View Post
. . . do i cut a small hole where the shocker mounts should be
Cut a small hole?? - you must have experience of some very dodgy mechanics - No, you just remove the trim. It's pretty straight forward, all the fasteners are easily visible.
Woolly is offline
#3 Old 06-05-2013
On R170 there is a removable square plastic trim right on top of the bolt for the shock absorber for easy access =) I assume R171 should have smth similar.
#4 Old 06-05-2013
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 271 Post(s)
There are actually pre-perforated areas on the carpet on each side in the trunk where a little access hole can be cut, and then folded back when the job is done. But yeah, probably better to just remove the carpet entirely. It's all held together with expansion clips, and some torx screws.
Last edited by Durkatlon; 06-05-2013 at 08:08 PM. Reason: perforated, not preforated :)
Durkatlon is offline
#5 Old 06-05-2013
sokoloff's Avatar
Chats: 3
Quoted: 66 Post(s)
Why do you think the shocks need to be replaced on a four year old car?
Len
1999 E300D 215,000 miles
sokoloff is offline
#6 Old 06-05-2013
Banned for no reason !!!
Balearic Pete's Avatar
Vehicle: SLK55 AMG
Exactly what i was thinking also .. 4 years ?
and mad SLK 55 AMG Fanatic
Balearic Pete is offline
#7 Old 06-06-2013
peZonator's Avatar
Quoted: 8 Post(s)
many thanks guys i appreciate the help
so trim will come off and will check for the pre-perforated areas as i may need constant access to the top of the shocker....
so you ask why change shocks??? only 4 years old ... because i am fitting the KW Variant #3 suspension kit and will do some of the work myself .. will post photos up of my completed project soon...
Rear Bumper Removal... k3vhm SLK R172 General Discussion 33 06-19-2019 05:36 PM
Rear Center Console Removal lilred320SLK SLK R170 class DIY 29 08-02-2016 03:40 PM
Rear brake disc removal SLK55AMG Paul Nickless Tires, Wheels, Brakes & Suspension 0 05-01-2010 03:26 PM
DIY: rear spoiler removal and install, part 1 dltslk SLK R171 Class DIY 0 03-12-2009 12:55 PM
