Help with top mount urgently - Mercedes Benz SLK Forum
  • 1 Post By Avel Du
  • 1 Post By Delucas
#1 Old 08-15-2019
Brutinasuit's Avatar
Vehicle: AMG SLK 55 R171 2006
Other Toys: Fast Bikes, Track Bikes, Off Road Bikes
Hey guys - a plead to see if I am missing something. Suspension on the Left hand side is moving all over the place on the top of the strut.. Yes tighten it up but it looks like the previous owner has a strut brace there ? surely the suspension has some ties here ? Even for stock with those holes. What am I missing to return it the normal and just tighten it ?. Just looks stupid moving about like that..
Brutinasuit is offline
#2 Old 08-15-2019
Quoted: 2246 Post(s)
Unfortunately it is dark, so I can't double check vs mine.
But it doesn't look right.
Avel Du is online now
#3 Old 08-15-2019
Doh! You removed the cap. Missed that.
Can't find any good pics anywhere.
I take it that you looked underneath (inside the wing)?
@frogfoot
@Delucas
@Sneaky Pete
@Turdo2
@Dave2302
#4 Old 08-15-2019
Quoted: 6497 Post(s)
13:30 shows top
#5 Old 08-16-2019
Quoted: 1136 Post(s)
There should be no top suspension movement as such or end float play .
Top mount is worn / bearing or top nuts are insecure / loose .
frogfoot likes this.
Delucas is offline
#6 Old 08-16-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 332 Post(s)
Sorry for late reply been busy took a pic of the strut top on my 350 , took plastic cap off for you.
Mine have a small coating off grease on to help keep moisture off
You should not have loads of play in that area sorry to say , your center nut and strut top are off center , worn bearing or Damaged bent strut ect ...needs looking at to be safe
frogfoot is offline
#7 Old 4 Weeks Ago
Cheers guys. Thought the end play was excessive. I've booked it in for two new top mounts that will hopefully cure the issue as the wheel moves round loads..
