Tire wear inside, alignment and camber kits - Mercedes Benz SLK Forum
  • 1 Post By jet_fl
#1 Old 07-13-2019
Vehicle: White/beige 2012 350
Quoted: 82 Post(s)
Question Tire wear inside, alignment and camber kits
RF tire has some wear on the inside edge, when I asked my Indy mechanic he said a camber kit is needed to prevent that kind of wear. He made it sound kind of expensive and special, but a look on ebay came up with many cheap options including MB eccentric replacement bolt, 000-333-09-71 / 0003330971 / Mercedes Alignment (not sure if that is front or rear). What I am wondering is if I want to deviate from OEM alignment, which as I understand it has some negative camber, and if so remove all the negative camber or just go to the lower end of MB suggested?
Some Questions:
Camber good/bad?
How much?
Just bump up the tire pressure 2 or 3 psi?
Which camber kit did you choose, what camber setting?
Mike6F is offline
#2 Old 07-13-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 192 Post(s)
Need a picture but excessive inner wear is usually improper toe out or wear on suspension parts.
How's the on center and pull?
VII7 is offline
#3 Old 07-15-2019
Quoted: 208 Post(s)
Both BMW and MB like to wear out the inside of tires faster than other cars. I think that is part of why they feel so solid. If you are stock height then I would get an alignment done to see what the issue is. Like VII7 said, it isn't necessarily camber. If you lowered your car, then that will add camber. I bought the full links for my car as I lowered it, but don't have them installed yet. The eccentric bolts are weaker than the stock ones, so I am always leery of using them, but I know many do. If the toe is off, then that is adjustable already.
jet_fl is offline
