Replacing rear coil springs a big job or no? - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By Mensra
  • 1 Post By stu32
  • 1 Post By Mensra
  • 1 Post By Wild Bill
#1 Old 07-09-2019
Hi folks, as I mentioned in my "Is my 320 jacked up?" post, I got correct size (and very good quality) tires for the rear, but if anything, the gap between the top of the tire and the wheel well looks even bigger. But I got "blue dot" rear coil springs off a low mileage SLK320, and that should return it to normal. But the guy who put on the tires said it was a big job to swap them in. I was surprised because it seemed like it took no time for the junkyard to get them off the old SLK. The guy said the control arms or suspension arms or whatever that is, and the shocks, both need to be disconnected to get the spring in. Even so, it doesn't sound like 2-3 hours and $250 (labor only). I just didn't want to compress the springs myself. Thoughts? Thanks!
Gold5 is offline
#2 Old 07-09-2019
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
@frogfoot
@Dave2302
@stu32
#3 Old 07-09-2019
Mensra's Avatar
Quoted: 363 Post(s)
I changed the rear shocks and coil springs on my 2009 R171 facelift. Not horribly difficult.
Mensra is online now
#4 Old 07-10-2019
Quoted: 205 Post(s)
It takes a specialized spring compressor if you want to do it the easy and quick way. $70 on Ebay. If you don't have that spring compressor then yes it is a bigger job. 2.5 hours sounds about right for both sides.
jet_fl is offline
#5 Old 07-10-2019
Mensra's Avatar
Quoted: 363 Post(s)
I rented the coil compressor from my local parts store for $10.
#6 Old 07-10-2019
There'll be plenty of vids & maybe some on here for this job.
There's a diy for sure. But check the vids list.
https://www.slkworld.com/gtsearch.php...cing%20springs
#7 Old 07-10-2019
Not sure how similar the Crossfire is, but
https://www.bing.com/videos/search?q...70&FORM=HDRSC3
#8 Old 07-10-2019
Other Toys: Ginetta G32
Quoted: 92 Post(s)
I looked into renting a spring compressor kit when doing mine but ended up buying a Draper one off ebay. With the correct equipment it was a fairly straight forward job as already mentioned. I would not attempt it without the correct kit as you have to compress the spring quite a lot and a compressed spring is potentially dangerous.
stu32 is offline
#9 Old 07-10-2019
Mensra's Avatar
Quoted: 363 Post(s)
Nothing potential about a compressed coil spring being dangerous. I’ve seen a compressor break once, was not pretty. More dangerous than a loaded gun.
#10 Old 3 Weeks Ago
Vehicle: 2010 SLK350 with Sports Pkg
Quoted: 9 Post(s)
Not a fun job!
You need a tool similar to this one:
https://www.ebay.com/i/312586961755?...yABEgL2SvD_BwE
With it, the job is fairly straight forward and can be done using jack stands. Another method involves using a lift and a tall hydraulic jack:
I would imagine an independent job would take around three hours. In my neck of the woods, the typical labor charge is $100/hour, pretty cheap!
Wild Bill is offline
#11 Old 3 Weeks Ago
Quoted: 9 Post(s)
You might also be able to do this job using a bottle jack and jack stands, but you might also get boinked by the spring!
https://www.amazon.com/Torin-Hydraul...a-451432333148
#12 Old 3 Weeks Ago
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Did this on slk 350 easy job with a bottle jack, on r170 looks that you need to remove a few more screws.
i860 is offline
#13 Old 3 Weeks Ago
Quoted: 9 Post(s)
And you might be able to do it with a floor jack.
The problem with any of these methods that don't first tension the spring, is the lower wishbone or spring link (Mercedes speak) can get twisted making removal of the bolt that attaches it (to whatever) difficult.
