Slk200 removal of coil spring top nut - Mercedes Benz SLK Forum
#1 Old 06-17-2019
Vehicle: SLK 200 R171 silver 2005
Other Toys: Kawasaki Versys 650
Quoted: 20 Post(s)
Hi to all
Just compressed the front coil spring to replace but stumped by top nut and hex spindle
I tried to free the nut by striking sharply with a hammer but the top plate just spins with it
Any ideas appreciated ,I am using a 21 mm socket and the spindle is a 7 mm hex.
Paul
marauder1964 is offline
#2 Old 06-17-2019
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
@frogfoot
@Delucas
Suggestions for OP
#3 Old 06-17-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
I didn’t have this problem. Try using some penetrating spray. Mine came lose easily.
i860 is offline
#4 Old 06-17-2019
Quoted: 20 Post(s)
Hi thanks ,
So did you just strike with a hammer how did you stop the centre spindle from spinning
#5 Old 06-17-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Lift the rubber dust boot up on the spindle and put a pare of mole grips on the shaft as close to the top as you can get it .
Then hold the mole grips and free off top nut.
Mole grips will go between the gap in the coil
frogfoot is offline
#6 Old 06-17-2019
Quoted: 20 Post(s)
This may sound like a stupid question but it does undo anti - clockwise ?
I did try using a g clamp to stop the plate spinning when I strike the nut but no luck ,I have put some WD 40 on and will have be another go tomorrow
Paul
#7 Old 06-17-2019
Delucas's Avatar
Quoted: 1132 Post(s)
I use a special tool to hold the shaft as to cause no damage to shaft .
Nut undoes Anti clockwise .
Delucas is offline
#8 Old 06-17-2019
Quoted: 20 Post(s)
Thanks again , I have not compressed the spring sufficiently to get mole grips in there. I am thinking about a heavy duty off-set ring spanner and a 7 mm hex to hold the shaft. Although I have a good set of spring compressors I am a bit nervous about compressing it any more
I just need to hold of the spanner and hex wrench , I have every other size except those c'est la vie
Thanks again
Paul
#9 Old 06-17-2019
G0RSQ's Avatar
Quoted: 151 Post(s)
I used an electric impact driver to undo mine.
The rotation, and impacting eventually jars the nut off as the damper rod turns.
No need to hold the damper rod
Used one of these
https://www.machinemart.co.uk/p/clar...impact-wrench/
but only Ł36 a few years ago!
G0RSQ is offline
#10 Old 06-26-2019
Quoted: 20 Post(s)
HI to all quick update.
Managed to get the nut off using 7 mm hex/Allen key and a 21mm socket .
Using a mole wrench to clamp the socket did the job. I bought a decent set of spring compressors from screw -fix and managed to compress the spring enough to loosen the top hat /nut. However the only way I could compress sufficiently was to clamp the compressor onto the underside of the spring support plate. Getting it back on was a different matter as I could not then clamp onto the plate. I tried may configurations but ended up taking it to a local garage who did it using a hydraulic compressor, even that wasn't straightforward, that front spring is a awkward shape.
Anyhow sorted at last thanks for replies
Paul
#11 Old 3 Weeks Ago
Vehicle: 2010 SLK350 with Sports Pkg
Quoted: 9 Post(s)
You need a 7mm Allen wrench and one of these:
https://www.amazon.com/Schwaben-0030...gateway&sr=8-1
Wild Bill is offline
