Rear brake caliper bolts - Mercedes Benz SLK Forum
  • 1 Post By oldmanhouse
#1 Old 04-30-2019
Vehicle: SLK 230K, manual, 2001
I need some assistance identifying 3 bolts on the rear brake caliper. I sheared one off so the threaded part is now stuck inside the caliper, and I need to source a replacement once I've worked out how to get the old one out. I've checked EPC, but the part isn't listed as far as I can see.
They are not the 16mm bolts that hold the caliper onto the wheel hub, I think they are used to hold the two halves of the caliper together. I removed all 3 of them mistakenly thinking they were the mounting bolts, but after the caliper didn't move I realised my mistake and noticed the 2 x 16mm bolts behind the caliper! I overtightened one, and it sheared off.
The bolts have 11mm heads, and have thread only on the lower half. I've attached some identifying pictures, one annoted from Pelicanparts and one from EPC
oldmanhouse is offline
#2 Old 04-30-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 892 Post(s)
Go on ebay and buy a second hand caliper.
i860 is online now
#3 Old 04-30-2019
I was hoping to avoid that if at all possible! A used caliper isn't very expensive but it can't be less than a single bolt
On looking though, it does seem these bolts come as a part of the caliper from new so they probably weren't meant to be removed, so perhaps I am resigned to replacing the whole caliper. Seems a waste, but it's a lesson learnt - make sure you're clear what you're unbolting!
MartinatMersea likes this.
Rear brake backing plate removal GeoffL SLK R171 General Discussion 12 07-01-2019 03:42 PM
SLK 200 UK Rear Brake Strip and Rebuild johnnyg SLK R171 Class DIY 3 04-17-2017 03:37 AM
New Front Brakes 2000 SLK230 SLK R170 class DIY 20 12-28-2014 01:46 PM
Ceika Big Brake Kit Stinger Performance MODS for the R171 12 05-12-2014 02:50 PM
Lucas brake caliper ben721364 SLK R171 Class DIY 8 03-11-2011 05:12 AM
