R170 Brake Performance? - Mercedes Benz SLK Forum
  • 1 Post By fotofreak
  • 1 Post By ixion
#1 Old 04-15-2019
Vehicle: 1998 SLK 230
Other Toys: 21' Hurricane Backwaters Center Console
I have been restoring a 98 R170 which has sat a few years in a garage. I am now working on the brakes, which I though felt a little soft. Mind you that I have not driven a 20 year old car for a while, and when I then drive the 2017 Audi A4, I over step the brakes with a jerky stop. So I first bled the master cylinder and then the wheel brakes without a change. The front pads were low, so I then replaced all rotors and pads with Brembo ceramics. The bedding process proved that the car can effectively stop, but still the casual stopping in traffic seems to need a bit more pressure to stop. Am I overthinking this, as I am trying to bring the car into spec, and just don't know what to expect from the car?
fotofreak is offline
#2 Old 04-16-2019
Quoted: 2213 Post(s)
I doubt anyone can answer that question without driving your car and knowing the model very well.
I sympathise.
I have a 55 with 6 pots, the wife has a 350 with sports upgrade. Only 2 years different.
Her brakes are fine, but I have to be very aware of being in the 350 when I drive it.
The good news, some 170 owners have upgraded the brakes.
Several threads on the topic.
One thing that you might try, racing brake fluid.
Needs changing more often as it is even more hygroscopic, but it does make a difference.
Avel Du is online now
#3 Old 04-16-2019
ixion's Avatar
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 41 Post(s)
My 170 (230 Facelift Model) will stop on a sixpence (dime). My Brake system is Standard, just well maintained. No problems at all.
Other 170's I have driven also perform similarly.
Maybe the Brake Servo is not performing to spec. Also check the Rubber pipes to Servo. There is also a seperate Vacumn Pump.
Also change Brake Fluid unless you know age of it.
Finally - Suggest you put "Brake Servo" in the search box on the site - you will get about 80 Results.
Hope this will help.
fotofreak likes this.
ixion is offline
#4 Old 04-16-2019
I sympathise.
Power bleeding the system, twice, was the first thing I tried, so the fluid has been well replaced. I wish I could drive another 170 of that era.
#5 Old 04-16-2019
You're in Florida.
Why not ask if anyone with an identical car will meet up with you?
They could drive yours and comment if better/worse than yours.
Or vice versa.
#6 Old 04-16-2019
Is there a way to search the membership profiles to find those that may be close to me?
#7 Old 04-17-2019
Interesting, my version of the car pulls vacuum directly from the engine manifold. Looks like they may have improved the brake system with the facelift to pull vacuum from a dedicated pump (not on my car). I did the typical brake pedal checks for the booster and check valve, but I want to check actual vacuum to the booster through the check valve next. Thanks.
Introducing the Ceika Performance Big Brake Kit! Stinger Performance MODS for the R171 32 09-08-2018 08:36 PM
R170 What is the correct rear brake pad size? Waiheke Tires, Wheels, Brakes & Suspension 5 09-24-2017 11:16 PM
R170 Brake Upgrade 200K question vinnypt Tires, Wheels, Brakes & Suspension 1 12-11-2014 12:55 AM
R170 Performance Mods SirClass SLK Parts Wanted 1 05-25-2014 11:15 AM
R170 rear brake overhaul brynevans6 Performance MODS for the R170 2 01-31-2013 02:03 PM
