SLK 55 brake pad experiences? - Mercedes Benz SLK Forum
 29Likes
#1 Old 04-14-2019
Quoted: 887 Post(s)
I am looking for new front pads for Upah and I can't seem to find any consensus searching here - most of the discussion here seems to be about the rotors. I'd love to hear your thoughts on pads. I've searched MB, fcpeuro, rockauto, and the local parts stores.
The pads I'm replacing look to be metallic - lots of shiny flecks in the pad material. I'm wondering what the group experience here is with any of the wide variety of pads available. If you search online, you can find them from $30 to $220, with a wide variety of compositions - organic, metallic, ceramic, ferro-carbon, and others.
I have the 340mm rotors with six-pot calipers.
bartbrown likes this.
efair is offline
#2 Old 04-14-2019
Quoted: 6460 Post(s)
https://www.slkworld.com/tires-wheel...o-pads%85.html
#3 Old 04-14-2019
Quoted: 887 Post(s)
So you like the Akebono's? Do you know if they are metallic, ceramic, or what?
efair is offline
#4 Old 04-14-2019
I believe...
AKEBONO EURO® ULTRA-PREMIUM CERAMIC BRAKE PADS
https://akebonobrakes.com/euro
jet_fl likes this.
#5 Old 04-17-2019
Quoted: 887 Post(s)
I couldn't find the Akebono's in the right size - the EUR847's appear to be for the four-pot calipers (based on the photographs at least). The whole process of find brake pads for Upah's six-pot calipers has been problematic. Most of the retailers have incorrect cross reference information it seems - their photos show them as the wrong pads in most cases. And many don't provide details about their composition.
efair is offline
#6 Old 04-18-2019
Quoted: 208 Post(s)
I wouldn't trust photo's, most just use a stock brake pad photo for that brand.
jet_fl is offline
#7 Old 04-18-2019
55russamg's Avatar
Quoted: 665 Post(s)
Question
Padgid do not bite as much as the original Brembo pads.
Ceramic are good and less dust, I don't know the best brand.
@Col
Col likes this.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#8 Old 04-18-2019
Quoted: 887 Post(s)
I believe...
AKEBONO EURO®️ ULTRA-PREMIUM CERAMIC BRAKE PADS
I mean, what is the exact Akebono part number? I saw this link previously, and visited it, but found no way there to find an exact part number for the 6-pot, 340mm fronts.
efair is offline
#9 Old 04-18-2019
you asked me if ceramic, so that is what i posted.
#10 Old 04-18-2019
Col
Col's Avatar
Quoted: 714 Post(s)
I’ve just put EBC Redstuff ceramic pads on my R172 SLK55. I previously put similar Redstuff pads on my R171 SLK55. I’m a fan of them but I’ve not tried any other ceramic pads to compare. Akebono I’ve heard of but couldn’t find pads for my car here in the UK.
The initial bite from EBC Redstuff pads is not as sharp as standard semi-metallic pads but is more progressive. That said if you need to stop quickly applying more pressure on the pedal will compensate.
They produce very little dust which is easily cleaned off and does not fuse to the wheels like the metallic dust does.
Not done significant mileage on a set of pads yet so can’t comment on life.
If you can get them, try them! You might like them!
SoopRoop, Trev5 and 55russamg like this.
I'm not mean... but I am 'roofless' at every opportunity!
- SmartTOP
- Blacked Out Front Grille
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
- Vath X-Pipe and Modified Rear Silencers
- Ispiri ISR6 Alloys Wheels
Col is offline
#11 Old 04-19-2019
Quoted: 887 Post(s)
I ordered "Beck/Arnley 0891873" from Rock Auto, the box arrived in two days. The box was re-taped having been previously opened (which plays into my theory that the cross-reference data is incorrect - somebody returned these). It's a blue box with "ATE Original" branding, and Beck/Arnley stickers put over the existing ATE nomenclature. That's at least reassuring since I've seen many ATE brake parts in the last 50 years... I can make out the ATE part number - 604806 - which I found on ATE's web catalog, and it shows as designed for Brembo braking systems (which is also reassuring). However, there is nothing about the composition shown on the box or in the catalog. I think I'll put them on, and if the dust is excessive I'll replace them in the fall.
efair is offline
#12 Old 04-20-2019
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 141 Post(s)
Just had to replace pads and rotors on my 6 pots. I reckon the floating/drilled/grooved 6 pot set up is pretty overspec'd for road use anyhow so I wasn't too worried about extra bite. If it's anything to you I replaced with new Brembo rotors and pads and 200 miles in, the feel and performance is exactly the same as the originals which to me, is exactly what the doctor ordered!
Maya ~Tapatalk
55russamg and Robbie4T like this.
osi is offline
#13 Old 04-21-2019
Quoted: 887 Post(s)
Best $50 tool purchase in a while
Although I would've liked to have made something myself... Brake pad spreader. And I learned a new trick - open the bleed screws instead of the reservoir.
File Type: jpg 15558665296061787239730_1555866579226.jpg (28.4 KB, 7 views)
Trev5 likes this.
efair is offline
#14 Old 04-24-2019
Vehicle: Silver/Red '09 SLK 55
Other Toys: 89 Ford Probe GT, 02 WRX SportWagon
Quoted: 27 Post(s)
Send a message via Skype™ to SoopRoop
I've used EBC RedStuff pads on my 171 55 fronts, and love 'em! Braking is easy & progressive. Stomp 'em & feel your eyes strain! Stops quicker than my friend's C7 from 80mph, repeatedly (no fade - use Valvoline synthetic brake fluid). Now, at nearly 100k miles, I have to FINALLY replace my rear brake pads (have just under 50k on my EBC fronts).
Col likes this.
SoopRoop is offline
#15 Old 04-25-2019
Col
Col's Avatar
Quoted: 714 Post(s)
Having covered 50K miles with the Redstuff front pads how is your rotor wear? Be interesting to know if these pads increase or reduce the rotor wear rate.
- SmartTOP
- Ambient Lighting
Col is offline
#16 Old 04-25-2019
Quoted: 27 Post(s)
Not sure... I'm at 49k miles for the new pads & rotors. Just had a Schedule B, and they said my fronts still look good. Does anyone (@Jbanks?) know the correct part # for the '09 55 rear pads? Is it A 003 420 30 20?
Col likes this.
SoopRoop is offline
#17 Old 04-26-2019
Seanhump's Avatar
Vehicle: 2005 SLK 55 AMG
Quoted: 424 Post(s)
Pagid on the front for me ..
As has been mentioned, the initial bite isn't as strong as OEM, but they do stop when you press the pedal ...
Not sure I'd go with them again if I'm honest ...
55russamg likes this.
Sean
Not the 'Probie' anymore..!
Mods so far...
Seanhump is offline
#18 Old 04-26-2019
Quoted: 2213 Post(s)
You can check for yourself here https://slk-links.neocities.org/EPCLINKS.HTM
#19 Old 04-29-2019
Quoted: 27 Post(s)
Thanks! Except, bad link... "Service Unavailable"
SoopRoop is offline
#20 Old 04-29-2019
Rupert, that link works for me
From mild to wild. My SLK 55 AMG transformation and swapped motor story. C63edition507 Performance MODS for the R171 53 12-19-2018 01:22 PM
55 AMG Rear Disc Replacement and Hand Brake problem HarryH SLK R171 Class DIY 2 06-18-2016 08:58 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
