Wheel Choices - Mercedes Benz SLK Forum
  • 1 Post By jet_fl
  • 1 Post By Avel Du
#1 Old 04-08-2019
Vehicle: 1998 SLK 230
Other Toys: 21' Hurricane Backwaters Center Console
Wheel Choices
I have been looking through Craig's list for a set of AMG wheels that might fit my car. I have found this list of confirmed wheel combinations from our site here:
Mercedes-Benz Fitting Chart and Wheel Fitment Guide | Alloy Wheels Direct
I attached the section that I am interested in.
My question is, how much latitude do I have as far as diameter/width/offset combinations as there are many wheel sets that came around on later year cars?
What should I look out for?
fotofreak is offline
#2 Old 04-09-2019
Moderator/RoTMorganiser
Quoted: 2111 Post(s)
Can't advise on sizes but check local laws on whether wheels can protrude.
The reason they cam up with pigs ears (the little fairing behind rear wheels)
was to comply with regs in some areas that wheels cannot protrude beyond the bodywork.
#3 Old 04-09-2019
Quoted: 179 Post(s)
This is america, there are no laws :P
Offset is the biggest one. The wider you go on tires then the less fudge factor you have. I would stay within about 5mm on offset if you are running the normal 225/245 setup.
jet_fl is offline
#4 Old 04-09-2019
Maybe in Fl, but in Ca even exhaling has emission limits
Mike Florey likes this.
#5 Old 04-11-2019
Offset
With everything the same, if you increase offset, does the wheel move in or out from the mounting position?
#6 Old 04-11-2019
b82012's Avatar
Quoted: 288 Post(s)
Higher offset moves wheels IN (but can be remedied with spacers, tho' not often recommended)... lower offsets move wheels OUT (protrude more outside the wheel arches).
Omo
b82012 is offline
The Following User Says Thank You to b82012 For This Useful Post:
Retro-fit gear shift buttons onto steering wheel mike350 General Modifications R171 55 05-24-2018 03:13 AM
Chosing New Wheel Rims. Woolly Tires, Wheels, Brakes & Suspension 16 04-30-2017 06:31 PM
Steering Wheel Fitting Advice Please. 56586 SLK R170 General Discussion 3 12-07-2016 07:48 PM
Huge P21S Wheel Cleaner Sale 20% off till the end DetailersDomain Caring for your SLK 2 07-26-2009 04:22 PM
Huge P21S Wheel Cleaner Sale 20% off till the end DetailersDomain Caring for your SLK 0 07-25-2009 09:15 PM
