Resolved - R&R 2005 R171 brakes, any help or videos appreciated - Mercedes Benz SLK Forum
  • 1 Post By bartbrown
#1 Old 04-06-2019
Vehicle: 2005 SLK 55 AMG
Other Toys: 1978, 1981 Yamaha SR500
Quoted: 42 Post(s)
Well, after looking at all my options and my bank account, Ive decided Im going to remove all four of the utterly worn-out rotor and pad sets on my 70K mile 2005 R171. All replacement rotors and pads will be Brembo (two-piece at the front). Ive seen some good (though LOUD!) videos at LegitStreetCars et al, I have the correct manuals, and the tools, and I hope the brains to actually do this.
Any advice, prayers, videos, and encouragement most welcome!
Thanks,
Bart
bartbrown is offline
#2 Old 04-07-2019
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 141 Post(s)
Wow.. seems like replacement season at the 6 pot club! I have just replaced my front rotors and pads but I'm ashamed to say I caved and had them done at my India. Lots of recent discussions on the subject for you to check out and many helpful replies to my request back in January. Anyway, good luck!
PS.. the Brembos look great and are supposedly an upgrade from the original.
Maya via Tapatalk
osi is offline
#3 Old 04-08-2019
Quoted: 205 Post(s)
If you have changed disk brakes before you will be fine with these. They are very straight forward. I think they might have had large E style bolts though (reverse Torx). I have a full set so it was not big deal for me. This kit is amazing for only $55. Has every Torx, E and safety torx bit you should need for the car.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jet_fl is offline
#4 Old 04-12-2019
Vehicle: 2006 SLK55 AMG
Quoted: 15 Post(s)
Did mine a few weeks ago, rears need some external torx sockets or better still spanners.
You need one for the caliper mount bolts and a smaller one for the wear sensor mount, sorry can't remember sizes.
The reason i say spanners is that space is limited, I didnt have any so had to remove the ARB drop links.
Fronts are a bit easier, calipers are attached with cap heads, m10 Allen wrench IIRC and some smaller hex sockets for the bridge piece.
The pad retention pins may also be siezed in place depending on how long since last out, best to check these first and get some easing oil on and allow to penetratell while you're doing the other work (and having a brew)
Other than that you will need a small torx key, T25 I think, to remove the disk retaining bolts.
GDCobra is offline
The Following User Says Thank You to GDCobra For This Useful Post:
#5 Old 04-13-2019
Quoted: 42 Post(s)
Thanks for the info, but Ive found a shop to do the whole job.
Bart
#6 Old 04-13-2019
Quoted: 15 Post(s)
Bart
No problem Bart.
I struggle to let a shop work on my brakes because:
1) They always want payin
2) I'm more than capable of doing the job and believe ill do it better. Most shops will do bare minimum.
GDCobra is offline
#7 Old 04-13-2019
Quoted: 42 Post(s)
Thanks for the info, but I found a shop to do the whole job
Bart
2005 SLK350 R171 without COMAND, on replacing the A20 with an aftermarket NAV unit ( LA_BENZ General Modifications R171 34 2 Weeks Ago 11:39 PM
