torque values please - Mercedes Benz SLK Forum
 3Likes
#1 Old 04-03-2019
Transp0rt3r's Avatar
Vehicle: 2001 MB SLK230 Kompressor (Lazulithe Blue).
Quoted: 21 Post(s)
Does anyone know the torque values for the rear calliper's halves? When they are being put together? I recently rebuilt and powder coated all four callipers with new seals, boots... Fronts are just one piece design but rear ones are held together by 4 bolts. Couldn't find any values out on the Internet so hope someone can chime in here .
Transp0rt3r is offline
#2 Old 04-03-2019
Quoted: 6424 Post(s)
@i860 @VII7
#3 Old 04-03-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 189 Post(s)
Disassembly of the caliper in that manner does not seem to be part of any official procedure, I can't seem too find any torque spec.
What thread bolt is it?
VII7 is offline
#4 Old 04-04-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 892 Post(s)
Can't find any value. I believe you can't undo the bolts.
i860 is online now
#5 Old 04-04-2019
Quoted: 21 Post(s)
Yes, I would assume caliper would simply be replaced at that point
At the top of the bolt it says “versus. 11.9” the pitch seem to be 1.0 metric.
Thank you for all the insights.
#6 Old 04-04-2019
Vehicle: 2005 200 model
Quoted: 12 Post(s)
Hi, "11.9" relates to the grade of material (steel). we need the diameter of the bolt to give you an accurate torque value. The pitch of 1.00 mm looks like M10 x 1 (metric). Try and screw it into a nut of a known size.
mileoman is online now
#7 Old 04-04-2019
Quoted: 12 Post(s)
correction that should have been m12x1 not m10 - sorry
#8 Old 04-04-2019
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 326 Post(s)
Are they 'one time use' torque bolts perchance? They certainly have a high tensile value [11.9]
Most [all?] manufacturers seem to advise against splitting calipers.
Windinmyhair is offline
#9 Old 04-04-2019
Other Toys: CLS63
Quoted: 189 Post(s)
For M12 115NM,
This is a steel to steel generic spec for reusable bolts, there is risk that this is not the case.
VII7 is offline
#10 Old 04-04-2019
Quoted: 12 Post(s)
Until we know what the diameter is we cannot give the torque value. the bolts could be 0.375(3/8") UNF thread but being european I doubt it.
#11 Old 04-04-2019
Quoted: 21 Post(s)
The diameter of the bolt is 6.3 mm around the neck and 6.7mm where threads are. I'll stop by the hardware store and see if I can match a nut of the known size Sorry for my non-technical lingo
#12 Old 04-04-2019
Quoted: 21 Post(s)
Yup, that's why I couldn't find ANY of the specs or procedure online or at the dealership
I did see quite a few rebuilding videos for Corvette calipers (they are two-piece as well) but they never mention any of the specs!!!
#13 Old 04-04-2019
Vehicle: 2009 SLK 2Look
Other Toys: Ford Fiesta Titanium 3Dr, Porsche 944S2
Quoted: 100 Post(s)
Good grief - just bolt them together with some loctite if you have to! There is no torque setting as they are not in under any load!
Gimme Shelter is offline
#14 Old 04-04-2019
Other Toys: CLS63
Quoted: 189 Post(s)
The torque setting is to ensure they do not become loose due to thermal expansion and vibration. The temperature in the caliper will likely exceed the operational limit for loctite threadlock.
VII7 is offline
#15 Old 04-04-2019
Quoted: 21 Post(s)
The nut that fit perfectly is M7x1.00.
#16 Old 04-04-2019
Other Toys: CLS63
Quoted: 189 Post(s)
M7 20nm
VII7 is offline
#17 Old 04-05-2019
Quoted: 12 Post(s)
20 Nm seems quite pow to me!!!
See attached
The Following User Says Thank You to mileoman For This Useful Post:
#18 Old 04-05-2019
Vehicle: SLK200 - R171 2004
Are you sure it reads 11.9? It's hard to see from the image. Generally engineering bolts are either 8.8, 10.9 or 12.9
Sprigger is offline
#19 Old 04-05-2019
Quoted: 21 Post(s)
I will take a look again but I am pretty sure it was 11.9 . Bolts are not large themselves - 20nm is about 14.75 ft lbs which isn it much
Thank you for looking up!
#20 Old 04-06-2019
Quoted: 21 Post(s)
Yup. 11.9
it actually says “verbus” not versus as I originally thought.
722.9 Transmission - Torque Converter Drain Plug gchetta SLK R171 General Discussion 2 01-29-2018 07:28 PM
manual/software w/ torque values clown SLK R170 General Discussion 6 11-30-2015 06:07 PM
engine mount bolt torque values clown SLK R170 General Discussion 8 08-24-2014 03:17 PM
Using torque wrench on spark plugs, help DIYGirl SLK R170 General Discussion 10 08-16-2013 02:07 PM
