I need to replace all rotors and pads on my 2005 r171 SLK55 AMG, but I don’t want to pay Mercedes dealer prices. - Mercedes Benz SLK Forum
 11Likes
#1 Old 03-26-2019
Vehicle: 2005 SLK 55 AMG
Other Toys: 1978, 1981 Yamaha SR500
Quoted: 42 Post(s)
1. Can anyone recommend high-quality — at least as good as OEM — reasonably-priced rotors & pads for all four wheels of my 2005 r171 SLK55 AMG?
2. Is there any performance/longevity/whatever difference between “silver zinc” plated or “black zinc” plated rotors?
Any serious opinions gratefully accepted.
Bart Brown
55russamg likes this.
bartbrown is offline
#2 Old 03-26-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 192 Post(s)
If I remember correctly your front discs are two part, if so don't expect a price anywhere close to normal discs.
You can try fcpeuro but stick to well regarded brands.
VII7 is online now
#3 Old 03-26-2019
Other Toys: CLS63
Quoted: 192 Post(s)
Also the zinc plating is removed from the braking surface at pad bed in.
The plating makes no difference in brake performance and the appearance will only be different on non contact parts of the rotor.
VII7 is online now
#4 Old 03-26-2019
Quoted: 6441 Post(s)
https://www.slkworld.com/tires-wheel...o-pads%85.html
#5 Old 03-26-2019
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
Either do it yourself, free labour or use an independent MB specialist for half the MB labour.
In the UK, many have source parts from europarts, typically Brembo at half the cost of oem.
I think Pelican parts are similar in the US.
Avel Du is online now
#6 Old 03-26-2019
55russamg's Avatar
Quoted: 660 Post(s)
Cool
Autodoc in Germany can supply Brembo parts.
Obviously I assume a bit more shipping cost to USA? Free to UK.
Autodoc pads and Sensors
P 50 113 £52.68
A 00 377 £3.24
A 00 470 £6.64
P 50 092 £54.81
These were around half price and are being fitted by an Independent MB dealer because I can't be bothered.
Eurocarparts front discs
10422187A £689.99 for the pair. Already fitted.
M4rCu5 and Avel Du like this.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
The Following User Says Thank You to 55russamg For This Useful Post:
#7 Old 03-26-2019
55russamg's Avatar
Quoted: 660 Post(s)
Question
One option also is to have the outer part of the front disc re-manufactured.
@ZeroZero
Do not discard the inner, I have saved mine so I can at my leisure have some outers made.
Cheers Russ
SmartTop
#8 Old 03-27-2019
Quoted: 42 Post(s)
Thanks, V117. My front rotors aren’t the two-part bi-metallic Brembo, like this:
https://www.slkworld.com/attachments...212_180744.jpg
But one-piece rotor and hat.
(Sorry for borrowing someone’s 2-part Brembo image, but I haven’t replaced my online image library yet)
Bart
#9 Old 03-27-2019
Quoted: 205 Post(s)
Bart
Are you sure those aren't your rotors? My 05 and 06 both came with those. Later cars switched to the non-floating rotors. FCP Euro shows only the 2 piece rotors for 05 also. These should be yours:
https://www.fcpeuro.com/products/mer...mbo-1714210112
I would recommend Akebono pads as they are good and have very little dust. I am not sure why FCP doesn't list front ones, probably call them and they have them. Great place to work with and they are in the CT also. They might even be able to do the work for you.
jet_fl is online now
#10 Old 03-27-2019
Quoted: 42 Post(s)
Duhhh... thanks for making me go out and look...
jet-fl: Thanks for making me go out and look to be sure — you’re absolutely right, my fronts ARE the Brembo two-piece rotors. My brain-fart was caused by being stuck in a chair with ice packs because of a lower back spasm for the past week+, so I was working from memory. At my age, memory isn’t eidetic, in fact it’s practically gone, as my wife reminds me often. Plus, I haven’t had this r171 very long, and it’s been a difficult winter. Those are the best excuses I’ve got...
Thanks again for your question, now I know I have to pay $350 per rotor. Anyone know if Brembo makes separate rotor disks to be used with the black aluminum (I think) centers?
Regards,
Bart
#11 Old 03-27-2019
Other Toys: CLS63
Quoted: 192 Post(s)
The assessment and work of re using the hats should only be done by a trained professional.
Also it's not very likely you'll find main disc only for far less than 350 (350 is actually pretty good!).
bartbrown likes this.
VII7 is online now
#12 Old 03-27-2019
55russamg's Avatar
Quoted: 660 Post(s)
Lightbulb
These people will make you some.
https://www.tarox.co.uk/contact-us/
Cheers Russ
SmartTop
#13 Old 03-27-2019
Quoted: 868 Post(s)
I was wondering about this - how to ensure they're parallel to the hat. Are any special tools required for this task?
efair is online now
#14 Old 03-28-2019
Quoted: 42 Post(s)
As a long-since-retired engineering machinist, the old way would have been to assemble the iron rotor and aluminum hat, chuck them in a lathe, then hand-turn the lathe to measure run-out of the rotor, then flip the assembly, and measure the run-out of the aluminum hat. These days it’s a similar process, but with a dedicated machine instead of a lathe, and a fixed measuring laser. Given that Brembo has carefully machined all surfaces involved — the hat to the hub, and the rotor to the hat — everything should come out well within spec.
Thanks to 55russamg for the link, I have contacted www.tarox.co.uk and await their answer.
Bart
#15 Old 03-28-2019
Other Toys: CLS63
Quoted: 192 Post(s)
Ensuring geometry is only part of the work, the other critical aspect is assessing which hardware is in a good enough condition to be reused and which should be replaced.
A front brake failure is likely to result in serious consequences due to the tendency to fail when needed the most (under high demand).
I do not recommend this path for anyone without the proper training and experience.
VII7 is online now
#16 Old 03-28-2019
Quoted: 42 Post(s)
@ZeroZero
55russamg: Thanks for the info! Can you tell me how the inner aluminum hat is attached to the outer rotor, and what you’d need to put the assembly back together again with a new rotor?
https://dyw03owr7vs3n.cloudfront.net...jpg?1496489061
Thanks again!
Bart
#17 Old 03-28-2019
Quoted: 868 Post(s)
I've not disassembled my two piece rotors yet, and will probably just replace all pieces soon... But it's at least with a discussion: After you measure the difference in run-out, hat vs rotor, do you then mark and adjust the many little bolts present? Or do you loosen them all, then follow some process to align them?
It does beg the question "why two piece rotors in the first place". Unsprung weight savings? Or what?
Do the rotors move in relation to the hat when driving? Or over time as the pads wear? Or are they rigidly attached to each other?
I wholeheartedly agree this is not an area where you want any uncertainty or compromises!
efair is online now
#18 Old 03-29-2019
Quoted: 205 Post(s)
When I was looking there was about a $50 difference per rotor to buy just the whole assembly versus just the rotor with no hat. It wasn't worth my time for $50 a rotor. Have you found the rotor cheaper somewhere?
#19 Old 03-29-2019
Quoted: 42 Post(s)
How can I tell if I have “AMG Performance Package Code 030”
I found a seller who is offering a pair of the 2-piece Brembo rotors for US 548.86. There is a caveat:
“Important part details: without AMG Performance Package Code 030”
How can I tell if I have the “AMG Performance Package Code 030” or not? I didn’t see anything on the data card.
Thanks!
Bart
BREMBO Set of 2 Front Brake Rotors CLK55 SLK55 AMG NEW
Price: US $548.86
This fits a 2005 Mercedes-Benz SLK55 AMG Base Convertible 2-Door 5.5L 5439CC 335Cu. In. V8 GAS SOHC Naturally Aspirated
#20 Old 03-29-2019
Quoted: 42 Post(s)
2-piece Brembo front rotors for USD 548.86 per pair
efair: I've not disassembled my two piece rotors yet, and will probably just replace all pieces soon... But it's at least with a discussion: After you measure the difference in run-out, hat vs rotor, do you then mark and adjust the many little bolts present? Or do you loosen them all, then follow some process to align them? [/QUOTE=efair;4512414
Bart: I believe you tighten the little bolts in a criss-cross fashion, rather than “going around the ring.” Not sure what what the torque value is for the little bolts, but I bet somebody does.
efair: It does beg the question "why two piece rotors in the first place". Unsprung weight savings? Or what?
Bart: I doubt the aluminum hat adds much weight to the complete rotor; my guess is heat dissipation — something aluminum is very good at — which would explain the rectangular aluminum stand-offs, which I think transfer rotor heat to the aluminum hat, but of course I could be completely wrong. Anybody know?
efair: Do the rotors move in relation to the hat when driving? Or over time as the pads wear? Or are they rigidly attached to each other?
Bart: They’re rigidly attached, and the rotors do NOT move in relation to the hat when driving.
efair: I wholeheartedly agree this is not an area where you want any uncertainty or compromises![/QUOTE]
Amen.
SLK55 front brake pads and rotors replacement WoOZY Performance MODS for the R171 60 05-16-2018 03:00 PM
SOLD: Used Rotors for SLK55 AMG 6-Piston (non p30) DavisAMG SLK Parts For Sale 4 04-07-2017 11:21 AM
Performance brakes, pads & rotors for your Mercedes SLK class carid CARiD.com 2 03-18-2015 08:17 AM
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
2006 SLK55 AMG (R171), 76K miles, $25, 900: 125K Ext Warranty Included slyburn SLK Cars For Sale 6 09-25-2012 05:22 AM
