Vibration through brake pedal - Mercedes Benz SLK Forum
  • 1 Post By Mountainaire
#1 Old 03-18-2019
Vehicle: SLK 230K, manual, 2001
Yesterday I noticed that when sitting in traffic with my foot on the brake, I could feel a slight tapping/vibration coming through the pedal. I couldn't feel it when braking, only when stationary. The tapping occurs at regular intervals, say every 2 seconds. I thought perhaps my pads are a bit loose, so I pressed down hard on the pedal to make sure there was good contact, but same feeling.
Any ideas? It's more obvious with the foot on the brake pedal, but can be felt (slightly) with your foot on the floor. Is there some braking mechanism down that area that could be loose?
oldmanhouse is offline
#2 Old 03-18-2019
Vehicle: 2012 slk 350
Quoted: 25 Post(s)
I would suspect ABS, but it could be engine related also. If I understand you feel it also when stop without your foot on the brake peddle. That means to me that it something on the engine.
Mountainaire is offline
#3 Old 03-21-2019
Quoted: 205 Post(s)
I agree it sounds like the ABS. Any lights on the dash while it is doing it?
jet_fl is offline
#4 Old 03-21-2019
LeonardoDaBenz's Avatar
Quoted: 1011 Post(s)
Not abs if stopped. If rolling unlikely abs unless it's slippery/sliding. Vibration in the pedal while coming to a controlled (or even harder) stop probably indicates a warped rotor.
I've learned to live with my warpedness
NOT serious just irritating.
As it only happens while you're already at a complete stop, then I got nuthin'.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is offline
#5 Old 03-21-2019
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 328 Post(s)
Loose/broken exhaust bracket?
Windinmyhair is offline
#6 Old 03-22-2019
Quoted: 205 Post(s)
Originally Posted by LeonardoDaBenz View Post
Not abs if stopped.
If the ABS is working properly, yes. The assumption is something is malfunctioning.
The exhaust is a good idea also. What kind of noise is it and can you feel it anywhere else?
jet_fl is offline
#7 Old 03-22-2019
Found this for abs malfunction. It's not authoritative but might give some insight
https://mechanics.stackexchange.com/...-caused-by-abs
LEN
(Moderator)
#8 Old 03-23-2019
Thanks for the replies. I've done a bit more driving today and noted a few things
* No warning lights/ABS light is on
* Can only feel when at a stop
* Felt through the brake pedal, but can feel with foot on the floor too (but lighter)
* Interestingly - can only feel it with the heater fan on! Could be something in the heating system
#9 Old 03-23-2019
BUT if the ABS light is on, then it's not the heater but something (probably) more serious that needs resolution.
Maybe speed sensors?
With no scanner (for codes) posted, we're only guessing here.
LEN
(Moderator)
#10 Old 03-23-2019
ABS light is not on. Sorry for confusing wording
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
R170 BAS/ESP/ABS/Wheel sensor & brake pedal glmce Tires, Wheels, Brakes & Suspension 27 01-22-2019 04:21 PM
55 AMG Rear Disc Replacement and Hand Brake problem HarryH SLK R171 Class DIY 2 06-18-2016 08:58 AM
Why More Drivers Should Brake With Their Left Foot jbanks15 Off Topic 13 04-13-2015 11:34 AM
