Can not remove rear discs - Mercedes Benz SLK Forum
 16Likes
  • 4 Post By Delucas
  • 1 Post By Avel Du
  • 2 Post By frogfoot
  • 2 Post By efair
  • 1 Post By G0RSQ
  • 1 Post By handh27
  • 1 Post By jbanks15
  • 1 Post By frogfoot
  • 3 Post By handh27
#1 Old 03-15-2019
handh27's Avatar
Vehicle: Slk 280 R171 year 2007
Other Toys: Bikes
Hello everybody
i spent 3 hours for nothing!!!
I have a slk 280 (07) and I wanted to change my rear discs and pads. I have not been able to remove the discs.
I have the impression that they are welded.
you have to know that the handbrake is removed, the small screw holding the rotors is removed and that I can turn the disc with my hand
I hit like a mad with iron hammer.
I did not try with a mass.
Can you help me?
thank you
handh27 is offline
#2 Old 03-15-2019
Delucas's Avatar
Quoted: 1132 Post(s)
Originally Posted by handh27 View Post
Hello everybody
Can you help me?
thank you
You need to adjust internally the inner brake shoe adjuster so the brake shoes contracts inwards enabling the disc to be pulled off .
Delucas is offline
#3 Old 03-15-2019
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Hello everybody
Can you help me?
thank you
Might be more here
https://www.slkworld.com/gtsearch.php...20disc%20rotor
US use rotors, as we use discs.
As Delucas says, handbrake adjustment is important. Others have been caught out by that.
@frogfoot
#4 Old 03-15-2019
handh27's Avatar
Other Toys: Bikes
but that's what I did. i can turn the disc by hand. really it s a nightmare
handh27 is offline
#5 Old 03-15-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
If you have done all of above try some heat on the disc face where it sits on the hub , let it cool down and spray some Wd40 ( be careful if you are saving the shoes ) between disc and hub flange , you can do this by using the wheel bolt holes. You will see a small gap between disc and hub , then leave it to soak in. Next knock disc off with hammer.
If its still stuck its big hammer time but you will end up pulling shoes off back plate ect and end up needing more parts, just how it goes some times
55russamg and Avel Du like this.
frogfoot is offline
#6 Old 03-15-2019
Quoted: 863 Post(s)
Hardwood block and hammer... Hit, rotate 90 degrees, hit, rotate 90 degrees, repeat...
frogfoot and Avel Du like this.
efair is online now
#7 Old 03-16-2019
G0RSQ's Avatar
Quoted: 151 Post(s)
I have had this problem on another car, spent ages heating-bashing-etc, then found and used this method:-
Worked brilliantly. However not tried it on an SLK so might not be possible on one.
Viviannetv likes this.
G0RSQ is offline
The Following User Says Thank You to G0RSQ For This Useful Post:
#8 Old 03-16-2019
handh27's Avatar
Other Toys: Bikes
hi
Thank you all for your help. 6 hours later and ola perseverance, I managed to dislodge. For that I drove 6kms by intermittently actuating, the handbrake to heat the mechanism and disengage it. I used wd40 and banged hard outside. Now it's over. I will post a 2 photos to show you the result of this human adventure.
frogfoot likes this.
handh27 is offline
#9 Old 03-16-2019
handh27's Avatar
Other Toys: Bikes
doesn't match for slk..thanks anyway
handh27 is offline
#10 Old 03-16-2019
Quoted: 6432 Post(s)
tip 4 u
use the 'quote' buttons at the bottom of any post you wish to reply to or quote
#11 Old 03-16-2019
LeonardoDaBenz's Avatar
Quoted: 1011 Post(s)
By thanking members individually, that thanks will remain in their profile forever. It's nice doing it in a thread but it's better
to use "the button".
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#12 Old 03-16-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Smile
Glad you got it sorted and if you ever end up on a ferry docking in hull I have a ramp you can put the car on and poke around before you go on your travels.....coffee not to bad as well
frogfoot is offline
#13 Old 03-16-2019
Viviannetv's Avatar
Vehicle: 2006 SLK280 (r171) aka Sheila
Other Toys: MercesesML430, Mercedes E320 avantgarde
Quoted: 7 Post(s)
Red face
Would this invitation to use your 'ramp' be open to anyone of us SLK owners who may be passing your area of Hull ?
Viviannetv is offline
#14 Old 03-16-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
Thumbs up
Yes and many have already been
Windinmyhair likes this.
frogfoot is offline
#15 Old 03-17-2019
handh27's Avatar
Other Toys: Bikes
as promise
hello boys and girls
as promise here are 2 pictures of the brake discs front and rear
Mtec for the 4 discs ( from uk)
front pads Ferrodo
rear pads twr-lucas
cheers
handh27 is offline
How to guide: Remove and repair heated seats mrrossi SLK R171 Class DIY 51 12-12-2018 05:14 PM
Interior Freshening up! XOFMOT SLK R170 class DIY 38 05-22-2018 09:53 AM
Install Front & Rear Shocks kapitand SLK R170 class DIY 0 10-29-2017 02:22 PM
Rear Brake Discs on 2005 SLK55 AMG Mark55 Tires, Wheels, Brakes & Suspension 9 05-05-2017 08:36 AM
SLK 350 Brake Discs upgrade SuzaFan Performance MODS for the R171 13 07-03-2010 07:08 AM
