Sick of the brake dust... - Mercedes Benz SLK Forum
 4Likes
  • 1 Post By HawkX66
  • 2 Post By HawkX66
  • 1 Post By HawkX66
#1 Old 03-07-2019
HawkX66's Avatar
Vehicle: 2007 SLK 350
Other Toys: Yes...
Quoted: 49 Post(s)
I'm going to be changing my brake pads soon. I saw someone post up the print out of the brake parts/part numbers according to someone's VIN in another thread. Would someone mind running that for my VIN?
Any recommendations on what pads to go with? That's all I'm planning on changing.
HawkX66 is offline
#2 Old 03-07-2019
Quoted: 6432 Post(s)
@i860 you got it or me?
taking my walk
#3 Old 03-07-2019
here ya go anyway
#4 Old 03-07-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 49 Post(s)
here ya go anyway
Thank you sir!
HawkX66 is offline
#5 Old 03-07-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 49 Post(s)
As far as types of pads go, I'd rather not go with ceramic. The bedding procedure is crazy and takes too long IMO. See below. I might end up with them, but I'd rather see what else is out there first.
Per EBC:
"How to bed in your new brakes for street/urban driving
BEDDING IN NEW EBC PADS AND DISCS
  • Use brakes with minimal pressure for first 100 miles from urban speeds of 30-50 mph only.
  • Drive a further 250 miles using slightly increased brake pressure and load UNLESS in an emergency in which case apply brake as hard as required.
  • Look for a full width contact across the pad depth( rotor braking band) from the outer edge of the disc to the inner and if not achieved allow a further 100-200 miles steady driving. You will see a blue-ish band evidencing contact across the rotor face. Until this band goes from the outer to the inner edges of the brake disc/rotor the pads have NOT yet fully seated. When installing new rotors, reduced width banding is quite possible due to various tolerances and slight misalignments in the vehicle chassis and is NOT a warranty defect or a reason to remove and inspect brakes. Many European cars have SINGLE PISTON CALIPERS and these tend to “Flair” open and cause the contact band described above only to be seen at the outer edge of the disc/rotor and work its way inwards taking up to 1000 miles to do so.
  • After full width contact band is attained make a further 10 stops from 60 mph to 10 mph in succession with a deliberate attempt to get the brakes hot. Some smells may occur even slight smoke during this final heat up stage of the pads in early life. Then coast the vehicle for a mile to allow discs to cool. Do not pull up and park vehicle with brake excessively hot. You must try to get the discs down to below 60-80 degrees C temperature before parking the vehicle.
  • When parked let brakes cool to a final cool-to-touch point. Before touching discs splash a few tiny drops of water onto the disc to asses its temperature to avoid burning fingers. If the water spots cause a “hiss” you have parked up too soon and should go out and drive slowly allowing the brakes to cool further.
NEW DISCS TAKE LONGER TO BED IN
  • Fully bedding new pads to decent condition worn discs/rotors may take only 200-300 miles but when new discs are fitted at the same time bed in times to achieve outer to inner edge contact ( full width blue-grey contact band as mentioned under point 4 above ) can be as long as 800-1000 miles due to extra components needed to be aligned to the vehicle. To Short cut this you can ( and EBC recommend should) have EVEN NEW DISCS Pro Cut Lathe aligned to your vehicle. This process removes only microns of new disc material and shortens bed in time by 75% of the time it COULD take giving you better brakes faster and avoiding hot spotting and pad glazing.
BADLY WORN DISCS/ROTORS CAN TAKE AN AGE TO BED IN
Discs/Rotors with more than 0.5 mm ( 0.020 inches) of lip at the outer edge or hollow in the centre of the braking area can take up to 2000 miles to bed in and will for sure cause Noise, brake fade,vibration and pad burning. Bad rotors can RUIN your pads. 95% of brake fade and noise complaints come from poor disc/rotor condition where the pads touch only at the outer and inner edges and have no chance to deliver an effective brake."
jbanks15 and Viviannetv like this.
HawkX66 is offline
#6 Old 03-07-2019
no problem with brake dust here
of course i clean the car every day
https://www.slkworld.com/tires-wheel...o-pads%85.html
#7 Old 03-07-2019
HawkX66's Avatar
Other Toys: Yes...
Quoted: 49 Post(s)
Ya, I know about you and your car cleaning OCD. I love it... I used to be the same way, but I don't have the time these days.
I'm still looking, but I found the EBC reds for $106. Seems like a good price for ceramics which is what I'll probably end up doing... I'll check out the Akebon next.
Edit:
Then again, Amazon comes to the rescue at $59.78 for the Akebonos... Guess I found what I'll be getting.
https://www.amazon.com/Akebono-EUR11.../dp/B003E24M82
HawkX66 is offline
The Following User Says Thank You to HawkX66 For This Useful Post:
R172 Rear Brake Pad Replacement WhiteRabbit SLK R172 Class DIY 33 02-13-2019 09:48 AM
55 AMG Rear Disc Replacement and Hand Brake problem HarryH SLK R171 Class DIY 2 06-18-2016 08:58 AM
Brake dust brake dust & more dust QSHIP Caring for your SLK 8 04-24-2011 09:23 AM
Chrome Rim Brake Dust Corrosion / Surface Rust mbpaul Caring for your SLK 8 08-12-2009 09:19 AM
