Rear tires wearing out on the inside. Do you recommend a camber kit? - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By anthonyliZardi
#1 Old 02-15-2019
Vehicle: 2005 SLK 350
Hey guys! I have an 05 SLK350 with 19" wheels. I always noticed the rear tires wear faster on the inside. I have done search but most people have lowered their car. Mine is stock. Better for the wife that way. So the question is do you think I have a bad suspension component like a bushing or do you recommend a camber it? I seeing several camber kits but don't know which one would be better or last longer. I have 117k miles.
Thanks, Tony
anthonyliZardi is offline
#2 Old 02-15-2019
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
Have you had the wheel alignment checked.
Not up on US prices but circa $60 I guess.
#3 Old 02-15-2019
After reading other post I guess mine is not bad and is normal a little bit more wear on the inside since it sounds like these car are set with a little negative camber.
#4 Old 02-15-2019
Might have the wrong member.
@Delucas did you raise awareness on this previously?
#5 Old 02-15-2019
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 525 Post(s)
Mine were a lot worse than that after 8k miles.
Terminal is offline
The Following User Says Thank You to Terminal For This Useful Post:
#6 Old 02-15-2019
Mensra's Avatar
Quoted: 363 Post(s)
That’s about normal wear. My 350 09 wore about the same. Anywhere from 9000 to 17,000 miles depending on the tire. Really didn’t matter how I drove it.
Mensra is offline
The Following User Says Thank You to Mensra For This Useful Post:
#7 Old 02-15-2019
Thanks for feedback guys! I really appreciate it.
Terminal and Avel Du like this.
#8 Old 02-15-2019
Vehicle: 05 55
Quoted: 525 Post(s)
They are certainly set with quite a bit of negative camber, which means if you 'hoof' it from a standstill, the inner edge gets extra wear. When I said mine were 'worse', I meant to say that they were not just more worn, but more uneven than yours too.
FWIW, check your fronts also!
Terminal is offline
#9 Old 02-15-2019
Front is good. I pretty much have replaced all components in the front. I just did the tie rods service so I'm taking the car for aligment on Monday. Putting two new rear tires tomorrow. That's why I was wondering if I should put one of those camber bolt bushing kit. I think the tires have me good mileage and it rides good so probably I will leave leave it as is. Just to be sure in checking the rear suspension tomorrow to see if I see something worn-out. Thanks
#10 Old 02-15-2019
Quoted: 205 Post(s)
It is a german thing, BMW's wear the inside a lot more also. I am going to have some negative camber taken out of the rear of mine as I am more worried about straight line traction, which I don't have nearly enough of.
jet_fl is offline
#11 Old 02-15-2019
Vehicle: 2009 SLK 2Look
Other Toys: Ford Fiesta Titanium 3Dr, Porsche 944S2
Quoted: 100 Post(s)
Your pics show that your tyres are under inflated, ie they should be flat tread on the ground. Hence the wear on the inner treads - made worse by a negative bias camber/toe-out
Gimme Shelter is offline
The Following User Says Thank You to Gimme Shelter For This Useful Post:
#12 Old 02-22-2019
Vehicle: 2005 R171 SLK350
Other Toys: 1992 Mitsubishi E39A VR4
I addressed my issue by ordering a pair of adjustable camber rods for unbeatable deal from China ebay (Taobao). Have been using them for more than a year and they have been working fine
I understand sellers in ebay also carry them. You may also search the internet there are specifications available for building your own in even better deal
yiuwa is offline
Drive Kit Plus -- Practical Experience & Review BertL SLK R172 General Discussion 3 06-13-2015 08:33 PM
Bilstein B12 Suspension Kit jameslk55 Performance MODS for the R171 25 12-02-2014 11:46 PM
Rear tires wingman General Discussion 1 05-28-2009 11:36 AM
Rear tires for slk55 wingman General Discussion 3 05-11-2009 03:36 PM
need help on choosing rear tires etyu SLK R171 General Discussion 9 09-09-2008 04:52 PM
