help with new wheels - Mercedes Benz SLK Forum
  • 2 Post By kevvy
#1 Old 02-12-2019
Vehicle: 1998 slk 230 mercedes benz
Other Toys: Have a toyota seden
Quoted: 11 Post(s)
G'Day everyone
I want to buy new wheels for my slk 170 from overseas , and I dont know nothing about wheels size and offset ,bolt pattern and hub bore.I am getting a lot of work done and my fenders will be flare as well.
these are the specs for the new wheels , I thought I would ask here first as people here know a lot more than the tyre shops over here in Chiang Rai
These are the specs
Thanks for the help
  • Rim Material: Alloy
  • Item Width: 55
  • Item Length: 55
  • Offset: 35
  • Item Height: 22
  • Rim Diameter: 19in.
  • Bolt Pattern: 5x112
  • Special Features: For car
  • Rim Width: 8.5
  • Item Weight: 14 KG
  • Hub Bore: 65.1
  • Number of Spokes: 5
  • Material Type: Aluminum Alloy
  • Number of Bolts: 5
  • Rim Structure: One Piece
  • I appreciate any comments as I do not know if they will fit.
File Type: jpg New-19-20-21-22-Inch-5x127-5x112-5x114-3-5x120-5x130-Car-Alloy-Rims-fit.jpg (35.4 KB, 6 views)
simplyslk and Avel Du like this.
kevvy is offline
#2 Old 02-13-2019
Quoted: 6442 Post(s)
Try this
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
#3 Old 02-13-2019
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
oh gosh.. where to start....
the width and offset look OK, but you may want to consider a staggered wheel setup or the rear will look like it's sitting in a little farther. or maybe try a wheel spacer.
If you are going with flares, you will want a wheel that is much wider than this, and/or has a much smaller offset. or, again, your wheels/tires will look like they are sitting far inside the wheel arch.
the big problem I see is that the center hub diameter of this wheel is LESS than the hub diameter on the SLK (65.1 VS 66.6).
hope this helps.
Turdo2 is offline
#4 Old 02-13-2019
b82012's Avatar
Quoted: 302 Post(s)
^^^^^THIS... plus
+35 offset on a 8.5" wide rim will work fine in either front or rear, but much better fit for front. You certainly should go with a staggered setup, 8.0-8.5" front and 9.0-9.5" rear width rims are perfect. Here is mine:
Front: 19"x8.5" +35 offset (235/35 tires)
Rear: 19"x9.5" +35 offset (265/30 tires)
Hope all of these helps...
Omo
b82012 is online now
#5 Old 02-15-2019
Quoted: 11 Post(s)
hope this helps.
Thank you , everything helps me .. cheers mate
kevvy is offline
#6 Old 02-15-2019
Quoted: 11 Post(s)
Originally Posted by b82012 View Post
^^^^^THIS... plus
Attachment 536517
As meatloaf use to say ..."you took the words right out of my mouth"smaller at front bigger at back ...Thanks mate ..if you see my light on call in for a beer ..
kevvy is offline
The Wacky World of Wheels El_Murcielago Tires, Wheels, Brakes & Suspension 2 07-25-2018 07:07 PM
R170, R171, UK - 4 Original Mercedes 17" alloy wheels fitted with part worn winter tyres. PenelopePitstop SLK Parts For Sale 2 11-23-2013 04:13 PM
AMG/OZ 3-piece "classic" wheels on SLK 32 AMG SLK_32_AMG General Discussion 5 08-27-2009 05:24 AM
