Calliper Torque settings - Mercedes Benz SLK Forum
 10Likes
  • 2 Post By i860
  • 2 Post By i860
  • 1 Post By Colin Newman
  • 1 Post By jbanks15
  • 2 Post By i860
  • 1 Post By i860
  • 1 Post By WolfDog
#1 Old 02-06-2019
Vehicle: 2012 SLK250 petrol
Hi All,
2012 R172 SLK 250 petrol
Can anybody give me the correct torque settings for a) the front brake calliper bolts, and b) the bolts for the calliper carrier bracket?
Colin Newman is offline
#2 Old 02-06-2019
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
@i860 do you have access to worksheet data for this model?
Avel Du is online now
#3 Old 02-06-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 895 Post(s)
Document attached
i860 is offline
#4 Old 02-07-2019
Thanks for that.
Do I understand correctly from that sheet that both the Calliper bolts and the Calliper sport bracket have the same torque setting?
I ask because a video I found showing replacement on an E Class, had VERY different settings for the two bolts - the calliper ones being lot lower.
Would appreciate advice here.
Many thanks
#5 Old 02-07-2019
i860's Avatar
Quoted: 895 Post(s)
Post your vin number to check .
i860 is offline
#6 Old 02-07-2019
Vin: Wdd1724472f037101
#7 Old 02-07-2019
Quoted: 6443 Post(s)
Here is your datacard while @i860 checks
#8 Old 02-07-2019
i860's Avatar
Quoted: 895 Post(s)
Same like the first doc.
i860 is offline
#9 Old 04-25-2019
Vehicle: 2013 SLK55, Diamond White/Red
Hi @i860,
Could you please help me with a related question?
I'm going to replace the front brakes and rotors on my R172 SLK55 (VIN WDDPK7FAXDF049992) and am wondering if the caliper torque settings are any different for AMG brakes from what you posted above for Colin. I've also seen references to the caliper support bolts being single use. However, the SLK55 parts diagrams don't show the bolt. I did find Caliper Mount Bolt - Mercedes-Benz (019-990-80-01) for the SLC43, which I'd think is the same since they're both R172 AMGs. Is it possible to confirm that this bolt is correct?
Any assistance would be greatly appreciated.
WolfDog is offline
#10 Old 04-26-2019
i860's Avatar
Quoted: 895 Post(s)
Yes torque stings are the same 115Nm
Bolts A1244210471
i860 is offline
#11 Old 04-26-2019
Thank you!
i860 likes this.
WolfDog is offline
Torque settings for Spring Replacement djtuffer Tires, Wheels, Brakes & Suspension 1 06-05-2018 06:32 AM
Torque settings Swin SLK R171 General Discussion 2 11-18-2017 06:59 AM
Brake Calliper Torque SLK 280 Wangler Tires, Wheels, Brakes & Suspension 11 09-27-2017 04:10 PM
thermostat housing torque settings Swin SLK R171 General Discussion 2 11-23-2015 02:10 PM
Torque settings - suspension russj Performance MODS for the R171 2 06-12-2013 09:36 AM
