HELP, How Do I Unscrew These?! - Mercedes Benz SLK Forum
#1 Old 02-01-2019
Vehicle: SLK 250 2014
Quoted: 196 Post(s)
I'm having such a hard time trying to unscrew these screws/bolts to change my brake pads. I'm using 13mm deep socket and ratchet.
Turning the screw counter clockwise I can see the top screw moving but it's not coming out. I cannot use the same socket and ratchet for bottom screws because they are too wide, hitting the brake wires. This is driving me insane.
What correct tools do I need? Thank you!!!!!!
Melania is offline
#2 Old 02-01-2019
Vehicle: 2012 SLK350
Other Toys: CLS63
Quoted: 189 Post(s)
Before continuing, those are the rear brakes, did you follow the procedure to retract the electronic parking brake?
VII7 is online now
#3 Old 02-01-2019
Quoted: 196 Post(s)
YES. I release the electronic parking and put brake pads into assembly position. I can heard them move. Took cap off of brake fluid reservoir.
Melania is offline
#4 Old 02-01-2019
Quoted: 205 Post(s)
Those are pins and they are usually greased up pretty good. This causes some suction and they don't come out as easy as you think they will. They will have quite a bit of threads too, so it takes some turning to get them out. Gearwrech is the way to go for the bottoms or you can just do a lot of turning with a regular wrench. Be careful not to strip them as they look pretty damaged already. You could maybe get by with a short socked and a wobble extension. I use wobble extensions a ton, they are great.
Decent set for cheap:
https://www.harborfreight.com/3-piec...set-67065.html
Idiot101 likes this.
jet_fl is offline
#5 Old 02-01-2019
Quoted: 196 Post(s)
Thank you! To loosen the pins, do I turn them clockwise or counter clockwise?
As for Gearwrech, what size would I need? I have 14mm, 15mm and they are too wide for the top and bottom.
Melania is offline
#6 Old 02-01-2019
Delucas's Avatar
Quoted: 1131 Post(s)
13 mm socket or spanner anti clock wise but you must hold the other end hexagonal socket with a spanner or it wont undo !
Further down from 13 mm socket is the other nut / bolt as such . [ 14mm - 16mm size ]
Delucas is offline
The Following User Says Thank You to Delucas For This Useful Post:
#7 Old 02-01-2019
Quoted: 196 Post(s)
@Delucas The other end hexagonal socket you are referring to is A or B (please see picture attached).
Melania is offline
#8 Old 02-02-2019
Delucas's Avatar
“ A “ hold with spanner tight / fixed at all times while undo 13mm hex head with socket anti clockwise .
Delucas is offline
#9 Old 02-02-2019
Quoted: 196 Post(s)
What size spanner tight for 'A'? I've tried 17mm, 18mm they don't fit. Both were too small.
Melania is offline
#10 Old 02-02-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 892 Post(s)
Try to use a 19mm if not use an adjustable one.
i860 is offline
#11 Old 02-02-2019
Quoted: 196 Post(s)
Is adjustable one the same as pliers? I tried pliers and didn't work either .
I wonder what of brake materials does Mercedes use. My rear rims hardly have any brake dust. Brake dust build up fast on the front ones.
Melania is offline
#12 Old 02-02-2019
i860's Avatar
Quoted: 892 Post(s)
Something like this
https://www.amazon.co.uk/Silverline-...table+Wrenches
If you want less dust, buy ceramic pads.
i860 is offline
#13 Old 02-02-2019
Quoted: 196 Post(s)
I bought ceramic pads. Do you think a 12 volt ratchet would be strong enough to unscrew the pins?
https://www.homedepot.com/p/Husky-12...34PC/305332588
Something like this
Melania is offline
#14 Old 02-02-2019
i860's Avatar
Quoted: 892 Post(s)
Don't know.
Use a longer handle ratchet or put a pipe to make an extension if you can't with the current one.
Make sure you have a good socket as i can see from the pic you round the head a little.
i860 is offline
#15 Old 02-02-2019
Delucas's Avatar
A should be about 14mm - 17mm it only a small caliper hex nut .
Delucas is offline
#16 Old 02-02-2019
Quoted: 196 Post(s)
I cannot loosen the pins no matter what. They are so TIGHT. I gave up
Now I have to find auto shops that would be okay with me providing my own brake pads. I'm okay with being charged more for labor.
Melania is offline
#17 Old 02-02-2019
Mensra's Avatar
Quoted: 363 Post(s)
You probably can find a shop that can break the seized pins loose and then finish the job yourself.
Mensra is offline
#18 Old 02-02-2019
Quoted: 196 Post(s)
@VII7
@Mensra Would the rear brakes have to be in assembly position if a shop only need to break the seized pins loose for me?
Melania is offline
#19 Old 02-02-2019
Mensra's Avatar
Quoted: 363 Post(s)
All they’re going to be doing is loosening them up, not actually removing them so that when you get to them they will still be loose. If they need to be in any particular position to be loosened the shop will take care of it.
Mensra is offline
The Following User Says Thank You to Mensra For This Useful Post:
#20 Old 02-03-2019
Delucas's Avatar
A decent 13mm short not long socket should be used decent ratchet and a good sharp strong pull should crack off the 13mm head !
Anti clockwise so left turn .
Failing that a long decent 13mm spanner with gloves on to gain extra pull .
But its 13mm hex socket looks new and your car is a newish 172 so should be easy to come off .
Drink some red bull or get a neighbour to crack it off for you its is an easy thing to undo .
Delucas is offline
Unscrew bolt on vario pump Bowo SLK R170 General Discussion 1 12-25-2018 07:02 AM
