Resolved - Suspension - to bumper or not to bumper? - Mercedes Benz SLK Forum
 13Likes
  • 2 Post By Delucas
  • 2 Post By frogfoot
  • 2 Post By Delucas
  • 1 Post By SilverSLK2010
  • 1 Post By Nivag_c
  • 1 Post By Nivag_c
  • 4 Post By Nivag_c
#1 Old 01-27-2019
Nivag_c's Avatar
Vehicle: SLK 280 2008
Other Toys: BMW 116i
So just had both front dampers replaced by the local MB dealer as one was leaking. I asked them to replace the springs while they were there too, as there was no extra labour needed.
But... took a look once at home and spotted that the damper shaft is totally open to the elements. They didnít fit any rubber bumper / dust cover / gaiter. I believe itís Part 7 in the diagram. Is that something to cause concern?
I know bikes have stanctions open to the elements but every car Iíve seen has bumpers. I really donít want to be replacing these sooner than expected due to damage, rust or excess wear.
Does this seem an issue?
Iíve a Jan 2008 280 with sports suspension.
Thanks.
File Type: jpg B54079AB-E84D-4E46-B5F0-7E498C6B199F_1548623738324.jpg (24.7 KB, 8 views)
File Type: jpg E4DFFEDD-B7AA-4A83-AEA2-45A743F2DB69_1548623816993.jpg (5.8 KB, 17 views)
Nivag_c is offline
#2 Old 01-27-2019
Moderator/RoTMorganiser
Quoted: 2198 Post(s)
@Delucas @frogfoot
You guys know about these sorts of things.
Avel Du is online now
#3 Old 01-28-2019
Delucas's Avatar
Quoted: 1132 Post(s)
They are fitted with a rubber flexible boot to protect from ingress / dirt / water etc
Either your old shocks did not have them on before hand or the tech guys when assembling left it off
Is the other side missing also ?
Check other side and ring them back but they may say you did not have them on old shocks ?
Even so they should have fitted them as were missing parts and are req !
Note my 2009 model has them fitted .
frogfoot and Avel Du like this.
Delucas is online now
#4 Old 01-28-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
@Delucas @frogfoot
I suspect the garage that did the work has some left over parts kicking about !!!
@navig_c
Delucas and Avel Du like this.
frogfoot is offline
#5 Old 01-28-2019
Delucas's Avatar
@navig_c
Or evidence is in the bin so they dont have to do the job foc ?
#6 Old 01-29-2019
Nivag_c's Avatar
Thanks for the advice guys... I’ll give the service advisor a call today and see what they say!
It just seems so hard to get a decent job done. I’ve had a newly fitted auxilluary belt fail after a garage replaced it, another body shop painted a wing a re-fitted it wrong, and now even MB seem not to bother fitting parts correctly! It’s such a battle!! 🤯
Nivag_c is offline
#7 Old 01-29-2019
Delucas's Avatar
Originally Posted by Nivag_c View Post
Thanks for the advice guys... Iíll give the service advisor a call today and see what they say!
It just seems so hard to get a decent job done. Iíve had a newly fitted auxilluary belt fail after a garage replaced it, another body shop painted a wing a re-fitted it wrong, and now even MB seem not to bother fitting parts correctly! Itís such a battle!! 🤯
Its such a simple straight forward job to do im well shocked at your issues .
Excuse the pun !
Plus you may need wheel allignment doing afterwards poss it may put it out .
#8 Old 01-29-2019
Long Time Member
frogfoot's Avatar
Vehicle: 2005 slk
Quoted: 328 Post(s)
i think you can buy a fully built up strut from MB.
without seeing your bill and the parts list on it i dont know if merc have fitted one of these built up units.
if they have merc will blame merc parts department and do the rework free to you and carry out a parts warranty claim and get paid again by merc uk.
frogfoot is offline
#9 Old 01-29-2019
Vehicle: 2010 Silver SLK 350
Other Toys: BMW 135i and big fat grouchy black cat!
Quoted: 108 Post(s)
The rubber boot is to protect the shaft on the strut. It must be there, or the shaft will eventually be damaged. They'll have to take the whole mess apart to put them in.
frogfoot likes this.
SilverSLK2010 is offline
#10 Old 01-29-2019
Nivag_c's Avatar
‘Shocked’ 😂 can see what you did there!
So called up the dealer today and they’ll get back to me tomorrow.
It looks like they’ve charged for the parts individually and not as a pre-made damper set, but we’ll see what they say.
Thanks for the advice too, it’s much appreciated... I do get fussy with my cars, but don’t want to replacing a bust shock any sooner than I need to!!
File Type: jpg 77EDF250-F5DE-4474-A1C9-5C640CD151F9_1548786601137.jpg (24.8 KB, 5 views)
Nivag_c is offline
#11 Old 01-29-2019
Turdo2's Avatar
Vehicle: 1999 SLK 5.4 M113 V8
Quoted: 346 Post(s)
I've had those bellows be in such bad shape that I never put them back on, but never had any long-term issues by not having them there. If anything, it's just slightly excess wear and tear on the upper seal on your shock.
Turdo2 is offline
#12 Old 01-31-2019
Nivag_c's Avatar
So, got a call from the dealer.
Parts are in order and they can fit them fairly quickly so the car is booked in for a few days time!
I’m so glad I’m a picky so and so, as how many normal MB customers wouldn’t even look or spot these bits were missing. 🤯
It’s exactly that excess wear of the damper seals that I want to avoid. These shocks cost a lot from MB so I want them to last as long as possible 😄
Windinmyhair likes this.
Nivag_c is offline
#13 Old 02-02-2019
Nivag_c's Avatar
Just back from the dealer after having the car booked in to get the bumper/gaiter fitted... 🤣🤣🤣🤣🤣
They actually thought it was little black plastic top mount cover disc inside the engine bay that wasn’t fitted! Hilarious!
And it does seem the gaiter might include the rubber bump-stop too, so that’s pretty important.
I got to show the technician what was missing this time and they understand what’s needed now, which is...
removal of the full damper, fitting of the bumper/gaiter, reassembly and another alignment check.
I even gave the part number for the rubber damper boot when describing what was missing (which I’m 99% sure I’ve got right as I got it from
... awaiting a date for my next booking 🤣🤣🤣🤣🤣
Hilarious!!!!!!!!!!!!
Nivag_c is offline
#14 Old 02-24-2019
Nivag_c's Avatar
So just to finish the story about the missing damper bumper / gaiter... Mercedes fitted them and checked the alignment free of charge.
Didn’t even have to quibble on cost or sign any paperwork on collection, just gave the keys, showed me to the cleaned car and once happy, I was off home!
At least it’s now sorted!!
Nivag_c is offline
DIY Front Bumper Removal AMG/Sport Pack Durkatlon SLK R171 Class DIY 11 2 Weeks Ago 11:35 AM
Removal/install front bumper (55, but its the same for all) JudgeMing SLK R172 Class DIY 6 06-11-2019 03:02 AM
Rear bumper cover replacement Aubrey4530 General Modifications R170 2 07-06-2018 06:46 PM
F1 teams back active suspension return Berliner Heckflosse Motorsports 2 02-19-2017 03:30 PM
Front bumper replacement.. INSURANCE WARNING! ebenk SLK R171 General Discussion 23 11-21-2015 03:50 AM
