55 6 pot front brakes - Mercedes Benz SLK Forum
 13Likes
#1 Old 01-18-2019
osi
osi's Avatar
Vehicle: 2005 SLK55 AMG R171
Quoted: 141 Post(s)
Just got an MOT warning about front discs and pads. Been getting warnings about this for 3 years now but while it has passed MOT and brakes work perfectly, it appears to be getting near replacement time.. EEK! A little surprised that the discs only lasted 60k miles but this seems to be normal and I guess this is the penalty for having a greater pad area. Incidentally, no warning lights yet? I only do about 4k miles a year. Anyway, I have surfed the usual posts but cannot find definite part #s for the 6 potters. Seems that the 55 is offered anything between 330 and 360mm disks with a combination of drilled, grooved or both. Brembo and Tarox seem to be predominant and I believe that Brembo where the OEM suppliers? Mine are drilled and grooved and I would like to stick with the original type. Eurocarparts list Brembos for about 750 each, a German supplier lists the same for nearly half altho Eurocarparts always seem to offer some kind of discount. Tarox are cheaper. Whatever, the first thing I need is the original part number. MB Club EPC has now gone! Any help out there please? PS. I know about floating calipers but are there floating discs too. The picture of the 360mm clearly shows a seperate hub mounting whereas others are all one piece. Does this indicate a floating disc maybe?
osi is online now
#2 Old 01-18-2019
Vehicle: 05 55
Other Toys: My little Pony
Quoted: 527 Post(s)
^ They are 340x32mm, floating discs. If you can sweat it out a while, EuroCP/CP4L will be holding a '50% off brakes sale' - and then you can pick-up the o/e Brembos at something approaching a reasonable price.
Brembo part. f.disc 09.9254.33
ETA: Just checked EuroCP -They have 45% MIDMONTH sale, for a pair:
Discount Code
REMOVE CODEYour Discount has been applied: ( Mid Month Sale - Ends Tuesday ) Subtotal: 1429.98Discount: - 643.49Total (inc VAT): 786.49
osi and Avel Du like this.
Terminal is offline
The Following User Says Thank You to Terminal For This Useful Post:
#3 Old 01-18-2019
Quoted: 6433 Post(s)
you can still get part numbers here:
https://slk-links.neocities.org
or post your vin
BassedOut likes this.
#4 Old 01-18-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Thank you Terminal and thank you Jeff. Strewth.. it ain't arf complicated! I guess the 360mm jobbies may be for the Black. OEM part No seems to be A 171 421 01 12 which corresponds with the Brembo 09.9254.33 but some retailers say that they won't fit? Would prefer to buy from EuroCP since they are only about 20 minute drive away but EuroCP neither give any description nor original Brembo part number, only their own. I may need to phone them. Since it's not critical yet I don't know whether to wait and see if I can extract another 5% from EuroCP or sell a kidney and buy now. Hey ho!
osi is online now
#5 Old 01-18-2019
ps33fount's Avatar
Other Toys: too many things to take care of and use properly
Quoted: 83 Post(s)
Minimum disk thickness is 30 mm, mine were 30.9 mm so it was legal to reuse them, they were straight, no hotspots or warpage. jfyi. saved me $1200 bucks.
ps33fount is offline
#6 Old 01-18-2019
Moderator/RoTMorganiser
Quoted: 2192 Post(s)
@55russamg I think you got your Brembos from europarts? Can you remember which ones?
#7 Old 01-19-2019
55russamg's Avatar
Quoted: 660 Post(s)
Thumbs up
These, I think that's the part number on the box.
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#8 Old 01-19-2019
55russamg's Avatar
Quoted: 660 Post(s)
Thumbs up
Here you go
Eurocarparts
Soak the centre pin with Plus Gas / WD40 or similar a few days prior to changing.
New Pads are also required, I didn't replace with Brembo pads and they aren't quite as good.
Cheers Russ
SmartTop
The Following User Says Thank You to 55russamg For This Useful Post:
#9 Old 01-20-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Much appreciated 55russamg. Very sexy and countersunk holes too! Don't think the originals were countersunk, unless that has worn off. Which pads did you settle on?
Maya via Tapatalk
osi is online now
#10 Old 01-20-2019
55russamg's Avatar
Quoted: 660 Post(s)
Thumbs up
I have some Padig part number 101221118 on Eurocarparts.
They work ok but are just missing that initial bite but are slightly less dusty.
I don't know too much about brake pads. Some have used Ceramic to reduce dust.
I may (quite possible) buy some Brembo pads?
Although the job is fairly easy to do it can be awkward to remove the centre bolt, that's why I mentioned soaking it with a release agent. It's not the retaining bolt that is the problem, it is the removal of the shaft part, the thing comes towards you making it a bugger to tap out with a hammer. "Use a steel hammer"
You will need to (unbolt) remove the Caliper to get the Disk off. Get some Tie Wraps ready and hang it up.
Don't undo everything or it could end up like this.....
Avel Du and Uncle Nobby like this.
Cheers Russ
SmartTop
#11 Old 01-20-2019
55russamg's Avatar
Quoted: 660 Post(s)
Thumbs up
Here are some photos of the Pin
You will need a Pin Punch or similar to Drift it out.
Cheers Russ
SmartTop
#12 Old 01-20-2019
Robbie4T's Avatar
Vehicle: SLK55 AMG 2008,
Other Toys: SuzukiGt200X5(1979),YamahaFZ6(2009), Honda Firestorm(2000),
Quoted: 81 Post(s)
330? 340 ? or 360 ? To ensure you get the right diameter, it's a good idea to either measure the old ones first, then measure the new ones in the shop, or take an old one with you when buying the new ones. You could also try GSF car parts. They have some shops in London.
SLK55
(2008) with -
performance pack,
most factory options,
NTG 2.5 comand upgrade
+ boot cargo nets
Go Fast ! Stop Faster ! Love those 6 Pots
Robbie4T is offline
The Following User Says Thank You to Robbie4T For This Useful Post:
#13 Old 01-20-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Thanks Robbie. Yes, have measured best I can and they're def 340.
Maya~Tapatalk
osi is online now
#14 Old 01-20-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Nice one! I think I'm going to entrust my indie this time. I know it's the expensive cowards way out . I'm not normally shy about car diy and I've done pads in the past on my Stag and Escort Cossie but in this case I'm not sure I trust myself especially with the bleeding etc. Klasse of Fulham have been very good so I'll let them tackle it.
Maya~Tapatalk
55russamg and Avel Du like this.
osi is online now
#15 Old 01-20-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Phew.. bit the bullit and dunnit thru EuroCP 790 inc next day del. Jury still out on the pads. Going to do a little research on these next week. EuroCP list Padig which judging by the price must be good but do not list Brembo pads but I may email them and see. Thank you to all for your knowledge and advice.
osi is online now
#16 Old 01-20-2019
Vehicle: 2006 SLK55AMG
Other Toys: PlayStation3
Quoted: 9 Post(s)
Quick heads up.......if you are ordering front pads for 6pot calipers from the Euro/CP4L sites, the pads specified for the R171 SLK55 are the wrong ones and won't fit. You need the pads specified for the CLK55 6.2 AMG.
triple bogey is offline
#17 Old 01-20-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Same with the disks TB. A lot of the 6 pot discs are listed for the CLK
osi is online now
#18 Old 03-30-2019
osi
osi's Avatar
Quoted: 141 Post(s)
Hi guys, back again! Getting close to fitting my new rotors and pads. Quick question, does the 05 55 with the floating disks have sensors and if so, since they are relatively inexpensive, is it wise to replace them? Thanks in advance.
osi is online now
#19 Old 03-30-2019
Col
Col's Avatar
Quoted: 714 Post(s)
Yes, there is one on each axle, 1 front one back. If they arent damaged you can reuse your current ones but theyre cheap enough to buy
55russamg likes this.
I'm not mean... but I am 'roofless' at every opportunity!
- SmartTOP
- Blacked Out Front Grille
- Chrome Bonnet Fins
- Front Camera (Kerb Cam)
- Dash Camera (Hard Wired)
- Gel Resin Number Plates
- Acrylic Wind Deflector
- Ambient Lighting
- Vath X-Pipe and Modified Rear Silencers
- Ispiri ISR6 Alloys Wheels
Col is offline
The Following User Says Thank You to Col For This Useful Post:
#20 Old 03-30-2019
55russamg's Avatar
Quoted: 660 Post(s)
Cool
I didn't replace my sensor (One side only) but then I started to get warnings.
Two days ago I had Brembo Pads and Sensors fitted all round.
I used Autodoc in Germany this time for the parts, as mentioned above Eurocarparts didn't list the correct pads. It's always a worry ordering another part number. Autodoc were very good, they phoned to confirm I had ordered the correct parts and they double checked for me, can't ask for more than that.
Cheers Russ
SmartTop
vbcls
New Front Brakes 2000 SLK230 SLK R170 class DIY 20 12-28-2014 01:46 PM
Front brakes clicking mikemac SLK R171 General Discussion 1 05-03-2013 06:19 AM
SLK200 front brakes with E / S class brakes? asian_xl Performance MODS for the R171 2 04-04-2013 08:55 AM
Parts required for Front pads + Rotor change WoOZY Where to get R171 SLK Items 20 11-08-2012 11:00 AM
55 front brakes thomson_adam Tires, Wheels, Brakes & Suspension 20 07-10-2010 03:48 PM
