Resolved--Stuck locking wheel nuts (heads worn) - Mercedes Benz SLK Forum
 9Likes
  • 5 Post By jap
  • 4 Post By sprocket
#1 Old 01-05-2019
Location: 45 minutes from London - just far enough away !
Vehicle: 2005 SLK 350 with all the bits
Other Toys: Impreza Turbo GF8 Prodrive, Audi A6 Allroad Revo stage 1, Skoda Yeti
Quoted: 15 Post(s)
I've read a lot about 'rusty nuts' but my problem is that the heads of 2 of 4 MB locking wheel nuts will no longer turn with the MB key.
I've bought a new key which still skips out of the lug hole on both wheels when any turning force is applied.
I tried to attempt the common YouTube approach of putting a slightly oversized multipoint socket on top but they are too deeply recessed in the wheels for the socket to fit down.
Any ideas that have worked for you??? My winter tyres are still in the garage!
sprocket is offline
#2 Old 01-05-2019
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Try a smaller size and hammer it on the head bolt. If your heads are 17mm, hammer a 16mm on there and remove it like that.
i860 is offline
#3 Old 01-05-2019
Quoted: 15 Post(s)
The problem is that the bolt 'wells' are deep so I'm worried it would get jammed if I bashed it in with an impact drive or something and not be able to ratchet it out. On saying that Ive not much to lose !
sprocket is offline
#4 Old 01-05-2019
stagwcb's Avatar
Vehicle: Slk 250 CDI amg sport 2015
Other Toys: Triumph stag. Jeep Cherokee
Quoted: 92 Post(s)
You need a long reach socket .
stagwcb is offline
#5 Old 01-05-2019
LeonardoDaBenz's Avatar
Quoted: 1011 Post(s)
As has been said.
You may end up scratching/scraping inside the rim holes but there is no alternative.
Slightly undersized socket and a heavy hammer/2lb sledge and just hammer away. Try to keep that socket on straight by hammering straight. It'll take a good bit of hammering to get it on enough to turn.
Once it's on, you'll be able to turn it out. You might even be able to save the socket once you get it out (but unlikely).
This does work. Had to do it on my Magnum nuts when the key broke.
This vid shows nuts but same principle applies.
LEN
(Moderator)
Herbert Bayard Swope
LeonardoDaBenz is online now
#6 Old 01-05-2019
nimbusgb's Avatar
Quoted: 249 Post(s)
One of the reasons I use my local tyre place is that they use a torque wrench on wheel nuts/bolts.
Sodding idiots that use impact wrenches should have them jammed up their rear passages!
They cost me one set of black chromed bolts on the old 230 and a set of security nuts on sons 350!
nimbusgb is offline
#7 Old 01-05-2019
jap
Vehicle: obsidian black R171 350 facelift (2009)
I had this happen to my Peugeot last year after some idiot at a nearby garage used a pneumatic tool to tighten and ruin the head of one of the locking wheel bolts. Only discovered this some months later, while trying to swap tires myself.
Asked them to unf*ck this situation, they tried for an hour (attempted to drill a hole into the bolt, so they could apply a left-turning screw to get the thing out) - which led to nothing as those nuts are meant to be burglar proof and made of hardened steel. In the end they gave me a provisional quote of 250 EUR to get the bolt they ruined out and I gave them the finger and swore never to use their services again. Which is a bummer, as they are locate some 300 meters away from our front door.
Next step was to try to weld something to this bolt, but that failed because it was too deeply recessed as well. I started to have visions of spending the winter with my summer tires on that car
Finally, the internet came up with an answer: I found a shop that was recommended for this operation, some 50 kms away. Gave them a call, and they said they could fix it for 5 euros. Sounded like a good deal, so drove up there, and they fixed it with a "spiral socket" (is that an English term?)
In any case, the sockets looked like these: Spiraaldoppen - Bob's Carparts - Bob Slager automotive
He put one of these onto the bolt, and then applied an impact driver to loosen the thing. Less than 2 minutes of work, job done.
Stupid idiots in the neighbourhood garage.
nimbusgb, M4rCu5, Avel Du and 2 others like this.
jap is offline
The Following 2 Users Say Thank You to jap For This Useful Post:
#8 Old 01-07-2019
Quoted: 15 Post(s)
Thanks all. I took it to the garage - it took an hour's labour and a 'selection of tools' to remove the 2 worn nuts. They did really well not to damage the rear alloy as you know how deep the bolts are sunk.
sprocket is offline
The ultimate wheel cleaner? Sonax Wheel Cleaner DetailersDomain Caring for your SLK 5 04-06-2010 09:07 PM
Lug Nuts and Wheel locks stylezzza SLK R171 General Discussion 0 08-19-2009 08:12 PM
