16inch winter tyres fit slk 350 - Mercedes Benz SLK Forum
 10Likes
  • 1 Post By jbanks15
  • 3 Post By M4rCu5
  • 2 Post By mchild
  • 1 Post By i860
  • 1 Post By Gbarringer100
  • 1 Post By Sneaky Pete
#1 Old 12-25-2018
Vehicle: Slk 171 200 build 2004
Other Toys: Harley v-rod
Question do 16 inch winter tyres/rims from a slk 200 R171 fit a slk 350 R171 ?
Thnx
Ton
Ton NL is offline
#2 Old 12-25-2018
Quoted: 6432 Post(s)
from a search of our forum
this guy had 16 inch on his 200 r171
https://www.slkworld.com/tires-wheel...eels-18-a.html
#3 Old 12-25-2018
Yeah but do the 16 inch fit on a slk 350
Ton NL is offline
#4 Old 12-25-2018
I'll let the experts reply
but since the 350 comes with 17" wheels standard, thats why I didn't think of anything smaller than 17" will fit a 350
bolt pattern would be different to start
#5 Old 12-25-2018
this might help
https://www.wheel-size.com/size/mercedes/slk-class/
M4rCu5 likes this.
#6 Old 12-25-2018
Mmmhhh not listed for slk 350 only for slk 200 and slk 280. Reason for asking is that I have them for my slk 200 and also want to use the 16 inch for the slk 350 I am searching for so in winter time can fit them.
Ton NL is offline
#7 Old 12-25-2018
M4rCu5's Avatar
Quoted: 201 Post(s)
PCD is the same but it may well be a case of the 350 having bigger discs and/or calipers.
Similar to the R170 200/320, wheels interchangeable one way but not the other.
As Jeff says, wait for the R171 experts to turn up for a definitive answer.
jbanks15, Avel Du and Ton NL like this.
M4rCu5 is online now
#8 Old 12-27-2018
No experts available during Christmas I gues
Ton NL is offline
#9 Old 12-27-2018
@Sneaky Pete
@Seanhump
@mchild
@efair
@i860
#10 Old 12-27-2018
Star/DAS Registered Owner
Quoted: 499 Post(s)
Brake rotors and calipers are the same between the 350 and 280 so if there is some indication that the 280 and 200 wheels are interchangable then the 200 may well fit the 350 also. There is only one way to know for sure - try it.
jbanks15 and M4rCu5 like this.
mchild is offline
#11 Old 12-27-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Yes, 16" are ok for slk 350 standard.
As per my vin nr, only 17" are available but generic slk 350 wis shows 16" available.
i860 is offline
#12 Old 12-27-2018
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 99 Post(s)
The US 350 has larger rotors and different calibers which gives it 17 inch wheels. The 280 had different rotors and calibers and 16 inch wheels. The 200 was not offered in US.
Gbarringer100 is offline
#13 Old 12-27-2018
M4rCu5's Avatar
Quoted: 201 Post(s)
And just to add more confusion
Hit and scroll down to R171:
https://www.dcperformance.co.uk/upra...cedes/slk.html
200 = 288mm
Standard = 300mm
Seems the sports pack equipped 171's use a 330mm disc whilst the 350's from 2008 onwards use a 345mm disc .. interesting
#14 Old 12-27-2018
Quoted: 532 Post(s)
According this MB document
https://www.mercedes-benz.de/passeng...171_111115.pdf
for a 350 (Variante 3,FL and pre-FL) only 17 and 18 inch is allowed.
Check for yourself at
https://www.mercedes-benz.de/passeng...nkombinationen
Sneaky Pete is online now
The Following User Says Thank You to Sneaky Pete For This Useful Post:
