slk350 brake wear life - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By jbanks15
  • 2 Post By HawkX66
#1 Old 12-18-2018
Vehicle: 2006 SLK350, AMG trim, Pewter/Java interior
What's the average life or milage for an slk350 (171)? anyone?
Hal350 is offline
#2 Old 12-18-2018
i860's Avatar
Vehicle: SLK 350 R171 2004
Quoted: 893 Post(s)
Depending on driving style, disc and pad quality.
2 or 4 pods caliper?
i860 is offline
#3 Old 12-18-2018
Quoted: 6432 Post(s)
Join the gang! Your 1st thread should be your introduction so we can welcome you properly so post an introduction in the ‘New members introduce yourself here’ section. Click this: https://www.slkworld.com/new-members-...yourself-here/
If you wish to become PM (Private Message) capable or to ‘edit’, you need 15 posts. To get those 15 posts quickly, just go to the ‘New members introduce yourself here’ section and welcome enough new members as we welcomed you to obtain your needed posts to PM/edit. You can always pm a moderator.
Want to ‘like’ or thank’ someone’s comments? Use the ‘like’ button to the right or the ‘Thanks’ button, bottom right of any post you like. This saves you having to comment or use the 'quote' button so we know who you are asking or replying to or referencing.
Founding Member/Moderator/Ride of the Month Coordinator
#4 Old 12-18-2018
HawkX66's Avatar
Vehicle: 2007 SLK 350
Other Toys: Yes...
Quoted: 49 Post(s)
Seeing how you're in Framingham, Rt. 9, 30 and the Pike will eat them up with all the stop and go. Living in the country or doing a lot of interstate driving will make them last a lot longer. My point is, it's not a simple answer. It all depends on driving style, location and are you talking about factory parts or a/m replacements? I don't think you'll get anywhere near an accurate answer.
Avel Du and b82012 like this.
HawkX66 is offline
#5 Old 12-18-2018
Quoted: 532 Post(s)
As others already said, almost impossible to give an accurate figure.
But to give you a very,very,very rough idea:
Officially MB lists the wear factor as 1 mm/4000 km for the fronts and 1 mm/6000 km for the rears.
Brake pad lining for new OEM pads is (with pad backing plate) 20 mm for fixed calipers and 17.3 mm for floating calipers. Documentation doesn't list the thickness of the backing plate but lets estimate that at some 5 mm. Supposing you don't want to wear them out until iron touches iron I'd say you got some 11-13 mm to wear out. So that would be be some 48000 km for fronts and 72000 km for rears. Or 30000 and 45000 mi. Hypothetical.
Sneaky Pete is online now
#6 Old 12-18-2018
Trev5's Avatar
Quoted: 300 Post(s)
My 2010 R171/350 with the 4 pot "Sports" brakes up front lasted 49,000 miles on the original MB pads, before being flagged up as "low" on our yearly MOT Test.... (Which is surprising they lasted this long, considering the number of times I had to wash the front wheels due to brake dust... )
But most of these where quality SLK miles in the "country side" and being an "Advanced Driver" I anticipated a junction by lifting off the gas pedal sooner, rather than breaking hard just before a junction...
Though the larger front disc's where lipped & may need to be replaced before the 2nd set of MB pads expired....
Trev5 is offline
Front brake pad wear sensors Ade's A.M.G. Tires, Wheels, Brakes & Suspension 3 10-27-2018 11:02 AM
UK: SLK350 R171 Genuine Front Brake Pads Mark999 SLK Parts For Sale 1 04-25-2018 06:07 PM
Brake Pad Wear. Visit Workshop! craigwill55 SLK R171 General Discussion 5 09-16-2012 12:02 PM
Do Brake Rotors Have a Short Life?? gmabli General Discussion 9 10-29-2007 10:28 AM
