Best advice please - wheelnut key won't remove 2 wheels - Mercedes Benz SLK Forum
 4Likes
  • 2 Post By Redleader
  • 2 Post By Windinmyhair
#1 Old 12-16-2018
Location: 45 minutes from London - just far enough away !
Vehicle: 2005 SLK 350 with all the bits
Other Toys: Impreza Turbo GF8 Prodrive, Audi A6 Allroad Revo stage 1, Skoda Yeti
Quoted: 15 Post(s)
Hi
Due to a combination of wear and typical surface rust, the winter tyres are back in the garage as the tyre fitters couldn't remove two of the Mercedes locking wheel nuts.
I'm guessing this has happened to a few other people !? The key lugs lock in place but then jump out when enough twisting force needed to remove them is applied.
Apart from taking them to a garage to drill them out (?) any other ideas that have worked for you ???
(I will get some standard bolts or a new set of lockers once I've had the tyres put on !)
sprocket is offline
#2 Old 12-16-2018
Vehicle: 2008 R171 280 in Thulite Red
Other Toys: Holiday home in France
Quoted: 94 Post(s)
Try an impact wrench preferably air version. The rotary knocking action might shift it.
When fitting the new bolts use a torque wrench.
55russamg and Avel Du like this.
Redleader is offline
#3 Old 12-16-2018
Windinmyhair's Avatar
Other Toys: Lots of tools
Quoted: 328 Post(s)
Try a manual impact driver - the type you strike with a hammer. Less likely to make the key nut jump out compared to an air wrench.
Windinmyhair is offline
#4 Old 12-16-2018
55russamg's Avatar
Quoted: 660 Post(s)
Question
If they are worn like you say, I would say have the heads drilled off as you suggest.
I would get a new set of locking bolts, I assume Mercedes ones are very expensive ?
Cheers Russ
Metalic Mystic Blue - AMG V8
SmartTop
USB socket in Centre Arm Rest
Super White Fog Lamp Bulbs
55russamg is offline
#5 Old 12-16-2018
Quoted: 15 Post(s)
Ok thanks have ordered a new key only first just in case that works. Will then try the impact approach if it doesnt. I can see on youtube that there is a common approach to getting off that I didnt know!
sprocket is offline
Interior Freshening up! XOFMOT SLK R170 class DIY 38 05-22-2018 09:53 AM
A Tale of Two: Mercedes-Benz AMG GT by Hot Wheels & Majorette Berliner Heckflosse Off Topic 0 08-20-2017 04:02 PM
Set of 18 inch AMG wheels for sale, UK will777888 SLK Parts For Sale 3 01-01-2009 06:39 AM
Need advice on 19" wheels midget fidger SLK R171 General Discussion 34 07-22-2008 10:37 AM
